Fuel Starvation
STAMPIE
Town: Durbanville
Vehicle: '05 4L V6 DC
Real Name: Danie
Fuel Starvation
Post by STAMPIE »
I have the following problem with my 22R.
Going up-hill or driving on the open road at 120 km/h, the engine cuts out, due to a lack of fuel.
If I take my foot of the accelerator immediately, the engine keeps on running (idling). If I then slow down, it gets enough fuel to carry on driving.
Up-hill, I need to gear down, ending up in 1st gear moving very slow and blocking traffic behind me.
I've cleaned the fuel tank
I've replaced the fuel lines from the tank to the engine as well as the return pipes
I've replaced the filter
I've installed an electric fuel pump.
But the problem doesn't go away.
Could this be a carburator problem? If so, what could it be?
Quintin
Town: Umhlanga
Vehicle: Toyota Hilux D/C 2 x Diff lock, 33" MT Tyre, Lexus V8, Winch, Bull Bar and Tow bar.
Real Name: Quintin
Re: Fuel Starvation
Post by Quintin »
There could be a few reasons for this, and fuel line that is busy braking up on the inside and the rubber peaces is blocking the fuel flow to the carb, or your needle and seat can have dirt in not keeping the port open but blocking the flow of fuel partially into the carb or your float level is for some unknown reason to low maybe some gunk in the float aria. Some carbs had a small filter just before the inlet nozzle that can be dirty.
Toyota Fortuner 3.0 D 4 D 4X4 A/T (4 play). Hilux DC 4x4, Lexus 4Lt V8, Mikhem suspension met 50mm lift, 50 mm body lift, Bilstein Shocks extra length, 33" tyre, 8 J rims, 2 x Lockers, Snorkel. (Blou Job) en dan n Peugeot 107 (Quickie).
Re: Fuel Starvation
Post by Family_Dog »
I've seen this before. My guess is that this should be the first thing to check.
Re: Fuel Starvation
Your description sounds very much like the float chamber is not filling fast enough .... doesn't sound like a jet problem if the motor performs normally for a while and then starves. Since you have already replaced the lines and filters as well as cleaned the tank, you should as suggested look at any filters on the carb and open the float chamber to check the needle and seat as well as the float level. ;-)
STAMPIE
Town: Durbanville
Real Name: Danie
Re: Fuel Starvation
Post by STAMPIE »
Thanx for the advise.
I think it's time for the EFI.
Quintin
Town: Umhlanga
Real Name: Quintin
Re: Fuel Starvation
Post by Quintin »
EFT can work but much cheaper to clean a filter. :)
STAMPIE
Town: Durbanville
Real Name: Danie
Re: Fuel Starvation
Post by STAMPIE »
Quinten
It's booked for Monday for an EFI transplant.
Will keep you informed.
Rooies
Town: Strand
Vehicle: 1994 2.4i (22RE) D/C Raider 4X4
Real Name: Rudi
Re: Fuel Starvation
Post by Rooies »
Jy moet definitief na jou float kyk, miskien is hy nie reg gestel nie of hy haak dalk vas. Kry somer vir jou n hele carb kit hulle is nie duur nie daar is n nuwe needle & seed in.
ROOIES: 1994 2.4i (22RE) Raider D/C - 200 000kms - Brospeed Branch & Powerflow Exhaust
MIKEM Suspension & Gabriel Safari Shocks - "31 BF Goodrich AT - GOMAD Aluminium Canopy
Melvill & Moon Seat Covers - Safari Snorkel - Bushwakka Weekender Offroad Trailer
Quintin
Town: Umhlanga
Real Name: Quintin
Re: Fuel Starvation
Post by Quintin »
Pleas keep us informed i think you are going to love the conversion more power and less fuel if you behave off coarse. Sommer give us some nice picks as well.
