LED Spot and Bar Lights
Bfreesani
Vehicle: Nissan Sani 2.7TD
Real Name: David
Post by Bfreesani »
I have come across an amazing product I have decided to take on as a business venture.
Solo pod.JPG (31.45 KiB) Viewed 3433 times
Solstice LED 6100.jpg (54.88 KiB) Viewed 3433 times
The 6 LED Spot above is the size of a standard 6" spot light.
Lights bars also available.. 2,4,6,10 up to 28LED's
Some examples of what the lights looks like compared to standard lights on a motor cycle. Lights used in this demonstration is 2 x Solo pod 1 x 10 watt LED units..
Pricing of the Solstice series is as follows:
Solo Pod R 1200 (900 lumen)
Solstice 4100 R 4410 (3600 lumen) (equivalent to 300W+ halogen)
Solstice 6100 R 6100 (5400 lumen) (equivalent to 500W+ halogen)
Pricing of the new Reflex series (bar) is as follows:
2LED R 2595 (1800 lumen)
4LED R 4410 (3600 lumen) (equivalent to 300W+ halogen)
6LED R 6100 (5400 lumen) (equivalent to 500W+ halogen)
10LED R 8595 (9000 lumen) (equivalent to ????W halogen)
There are additional models available (up to 28 LED), but we will only bring those in on client order.
Some more stats:
Equipped with brand new 10 watt LED technology, each of the 10 watt LED’s produces 800 lumens. The XIL-S6100 series 60 watt 6” round off road lamp 4800 Lumens (500 watt halogen equivalent) and the XIL-S4100 series 40 watt 4” square off road lamp produces 3200 lumens (300 watt halogen equivalent). This makes them the most powerful lighting system on the market in such a compact design. Not only do they produce more light, they are also the most efficient with the 6100 series drawing only 5 amps, and the 4100 series drawing 3.3 amps. Due to their advanced electronic drivers, which are also responsible for variable 9-60 Volt DC input and their long life span of 50.000 Hours. Other key features include: Rugged die-cast luminum housing (provides optimum durability and heat dissipation). The Solstice series also features an IP68 ingress protection rated housing making them impenetrable to dust and, submersible under water up to 3 meters. The unbreakable polycarbonate lenses are housed by a 6061 aluminum face plate which doubles as a radiant heat sink to melt away snow and ice in frigid conditions. Their stainless steel mounting bracket features knurled aiming knobs for 90 degrees of adjustment and is centered on the profile of the lights which provides a slim 1.5” mounting depth. The Solstice series has also been subjected to a 6Grms vibration test to ensure their performance in high impact conditions (ideal for off-road, and industrial applications). Performance of these lights is better than Xenon HID lights costing twice as much.
Comparitive Light Values
Type Watt Lumen
Halogen 55W <1000
Halogen 100W <2000
Halogen 130W <2600
HID 35W 3200
HID 50W 3600
LED (4x10W) 40W 3200
LED (6x10W) 60W 4800
Later....
David
Hillbilly
lukestrugnell
Town: JHB
Vehicle: Fortuner
Real Name: Luke
Club VHF Licence: M18
Re: LED Spot and Bar Lights
Post by lukestrugnell »
One of the guys in the rescue unit has the 4 led spots on his car.
Even in the day they are ridiculously bright and blind people. Very cool :thumbup:
One question? Can you get green ones and can you get flashing green led's?
I need to make a flashing light bar for rescues! with green lights!
cheers
Bfreesani
Real Name: David
Post by Bfreesani »
lukestrugnell wrote:One of the guys in the rescue unit has the 4 led spots on his car.
cheers
Hi Luke, we don't have anything available right now for you flashing unit. Thank you for your feedback on your friends lights. These are truly lights that you have to see to believe.
Guys, we also have a full range of HID units and systems for upgrades and replacement of halogen. I just don't want to make things confusing with too much information.
Later....
David
Hillbilly
lukestrugnell
Town: JHB
Vehicle: Fortuner
Real Name: Luke
If you have ever seen these LED spots you will realise old spotlights are dead....these things are amazing!
Always wondered where to get them now we know.
Good luck with your new venture! :thumbup:
chopper
Post by chopper »
Luke,
Durability, especially under extreme conditions?
lukestrugnell
Town: JHB
Vehicle: Fortuner
Real Name: Luke
I think during rescues equipment is tested to the limit!
Ivor seems to have had no problem with his during rescues! I vote yes, I would buy a set if I had the bucks! :thumbup:
zepplin
Vehicle: Crooza VX 80 EFI
Real Name: Steve
Club VHF Licence: HC 127
Post by zepplin »
David, what are you going about deliveries for out-of-town orders?
chopper
Post by chopper »
This seems the way to go in the future; would like to get a closer look at it especially at nite time
It should also become more affordable with the passing of time?
Bfreesani
Real Name: David
Post by Bfreesani »
zepplin wrote:David, what are you going about deliveries for out-of-town orders?
Hi Zepplin
We would usually use Postnet Speed courier services at an additional cost of around R120 to a place like Cape Town.
Later....
David
Hillbilly
cprinsloo
Town: Nelspruit
Vehicle: 1998 D/C 4x4
Club VHF Licence: X52
Post by cprinsloo »
Um, some questions: how legal will this spots be?
One cannot buy 100W globes any more, so what will happen at a road block?
CP
1998 Hilux D/C Lexus VVTi
Post by CasKru »
cprinsloo wrote:Um, some questions: how legal will this spots be?
CP
Tell them this is energy saving bulbs :)
Interesting question and it would be nice to find out
Post by Family_Dog »
As the spots use low-power LEDs, this should not be a problem. What will be a problem is if the lights are not positioned correctly (i.e. aimed too hih or into oncoming traffic), the light they emit is positively blinding. I bought a Fenix TK-40 which runs off 8 (and even four!!) penlight batteries. The beam is the most intense I have ever seen on a torch and one cannot look into the beam at all.
Post by CasKru »
Family_Dog wrote:As the spots use low-power LEDs, this should not be a problem. What will be a problem is if the lights are not positioned correctly (i.e. aimed too hih or into oncoming traffic), the light they emit is positively blinding. I bought a Fenix TK-40 which runs off 8 (and even four!!) penlight batteries. The beam is the most intense I have ever seen on a torch and one cannot look into the beam at all.
You will only be able to use these as spot lights when Highbeam is switched on. They will be to bright for dimmed lights and fog lights with lots of bleed through of light.
Post by OOOOMS »
Another Q? Do they have or come with covers?
Bfreesani
Real Name: David
Post by Bfreesani »
(Ox4)ms, good question, someone asked me this today while I was chatting to them, so I have just directed the question to my supplier as I do not see anything like this in the brochures or website. I will post and answer as soon as I have one.
My truck look to be coming home tomorrow, so I can get my life back in order hopefully.
Later....
David
Hillbilly
Post by OOOOMS »
Tx for the feedback, where do you operate from if I want to see them, maybee OOOODS can buy me a xmas present :lol:
Rooikappie
Town: Table View - CT
Vehicle: 4x4 3.0KZ-TE 2002
Real Name: Lourens
Post by Rooikappie »
Is there anywhere we can view these LED lights
OR even better
Have a demonstration at night????
This will get your sales up.........
vastrap
Town: Polokwane
Vehicle: 2002 Mitsubishi Colt V8
Real Name: Jan
Post by vastrap »
Hi net 'n vragie.
Is die pryse soos aangegee vir een lig of 'n stel van twee?
Mens sit mos nie net een spotlight op nie.
Bfreesani
Real Name: David
Post by Bfreesani »
Both myself and my supplier are based in Roodepoort. He has all the kit and by far the better place to do a viweing. At night is probably the best so we can compare nicely with what you already have and he has all the technical data..
Vastrap, the prices are per spot or bar light.
Later....
David
Hillbilly
