No man, Andre! We don't post pics like this here.
That's just REALLY bad taste. What if it were to land up in the wrong hands.
I'm suprised the moderators haven't intervened yet :shifty:
Back wheel bearing collapsed so it lost all its diff oil through the oil seal Toyota will fix under warranty because the bakkie only has 40000km on and a bearing should not break on that low mileage :x :x
If you what to see what a Hilux can do click below
Mountain Man wrote:Looks like some of that 40,000Km is still left on the side of your truck.
That truck has worked did Baboons pass, Botswana Okavango Swamps in the wet and is currently No 1 in the Rebel 4x4 Series Standard Production Class for 2009
Ek ry nie 'n Santon 4x4 nie
Good to see you use it for the correct use. I used to call to little bumps and scratches on my truck "Passport Stamps" 8 ) becaue you could see where it has been and each "stamp" has a story.
Let us know when you are back in action.
Bloues wrote:Andre .......bly jy is weer mobile.......wat van foto van Saterdag se rivier storie ..... swartbaard het goed naam gemaak in die Pretoria area......
Ek sal hom bietjie vrae vir die foto's
