When braking...klakking sound occurs...
- HiluxJunkie
- Town: Middelburg MP
- Vehicle: 2001 Hilux DC 4x4 2.7i Raider
- Real Name: Simon
- Club VHF Licence: N15
Guys;
I do not know if this is serious. Did not have time to look yet. When I step on the brakes , there is a klakking snound comming from the front right somewhere. It only sounds once..klak and then stops even if brake pedal is still pressed. As soon as I release the pedal and step on it again it klaks again once then stop. Any ideas ???
![Image](http://i767.photobucket.com/albums/xx317/HiluxJunkie/4x4%20outings/DSC00846-1.jpg)
![Image](http://i767.photobucket.com/albums/xx317/HiluxJunkie/4x4%20outings/H6-1.jpg)
![Image](http://i767.photobucket.com/albums/xx317/HiluxJunkie/4x4%20outings/DSC00872-1.jpg)
![Image](http://i767.photobucket.com/albums/xx317/HiluxJunkie/4x4%20outings/hilux-1.jpg)
![Image](http://i767.photobucket.com/albums/xx317/HiluxJunkie/4x4%20outings/DSC04093-1.jpg)
- Scooter
- Town: JHB
- Real Name: Scott
Re: When braking...klakking sound occurs...
Sounds like the brake pads are hitting against the caliper when you brake. This means they are moving slightly when the force is applied to the disc and they are moving in the direction of the disc. Check you have the correct pads, and check all holding pins and bolts. Make sure you caliper is tight.
- HiluxJunkie
- Real Name: Simon
Thanks. Will do.
- Town: Port Elizabeth
- Vehicle: Hilex
Also check your wheel bearings. A loose bearing will make the disc wobble(with the loose wheel) and slowly push the pad back and then it needs to take up that slack when you hit the brakes. It will also make your brake pedal feel spongy.
Barto de Koning
- SYRON CONVERSIONS
- Town: Tamboekieland
- Vehicle: SFA HILUX
- Real Name: SIMON
Check the anti-rattle spring wires, maybe your vehicle does not have any or they are broken.
Do you feel any vibration on the steering wheel at the same time?
simoan
simoan
- Town: Pretoria East
- Real Name: Leon Brink
Also had a "clack-clack" sound on braking. Got a set of anti rattle clips from Toyota at R81 and voila, sound magically disappeared!
- HiluxJunkie
- Real Name: Simon
No vibration on steering. Klakking stopped by itself now. Will strip anyway to see if I see something funny.
- SYRON CONVERSIONS
- Real Name: SIMON
Have you had any rain since your first posting about this subject.
simoan
simoan
- HiluxJunkie
- Real Name: Simon
Yes. Why?
- SYRON CONVERSIONS
- Real Name: SIMON
Maybe after you had the rain, the water could have washed out any brake pad dust and this was causing the noise that you heard.
simoan
simoan
My Hilux has this funny screaming sound at the right front somewhere every time I hit a pedestrian
![Image](http://www.4x4direct.co.za/4x4direct-comm.jpg)
- Scooter
- Town: JHB
- Real Name: Scott
Ive had that before too Pieter, only mine faded as I got further down the road. ![Mr. Green :mrgreen:](./images/smilies/icon_mrgreen.gif)
- SYRON CONVERSIONS
- Real Name: SIMON
Tell me This screaming noise, is it a high or low pitch?
Xhosa, English, German, Afrikaanse, Latin, Dutch, Zulu, Spanish, etc :roll:
simoan
simoan
