My attempt @ DIY Canopy
- Vehicle: Isuzu D/C 2.8 & Toyota D/C 3.0 KZ-TE
- Real Name: Jose
Ok seeing that I need to mount a RTT and unfortunately the canopy that came with the bakkie is useless for this purpose I decoded to give it a go at building one.
More next week.- Mud Dog
Re: My attempt @ DIY Canopy
So far so good. The square sides rather than angled might not look as good but will give you a bigger base on the top of the canopy. I assume you're still going to add more centre slats. No need to put them so close though .... extra weight. Alu plate is surprisingly strong. We'll watch for the next set of pics. :D
- Real Name: Jose
Sides have a 7 degree slant, just to give it a bit of shape.
On the top its not getting any more slats, those are close to each other so that the RTT can mount on those lats.
- Town: Springs
- Vehicle: Hilux 2700i
- Club VHF Licence: HC262
Are you going to put canvas or alu?
- Real Name: Jose
Aluminium
- Spartan
- Town: Vanderbijlpark
Ek wil nie vir jou vertel hoe om jou goed te bou nie maar die manne het n punt beet met die ekstra dwarslatte as jy aluminium gaan, sonder dit gaan jou plaat rattle en uiteindelik gaan dit uit skeur. Just a thought
MOBILITATE VINCERE
Spartan
Spartan
- Town: Howick
- Vehicle: 1998 Hi-lux 2,4 S/cab (p); 1997 Hi-lux 2,4 D/cab (p)
- Real Name: Harold
Am most interested in your DIY canopy as am wanting to build one myself to replace my 11 year old steel canopy which is showing signs of its age, rust & cracks.
Question: What thickness aluminium plate will you use?
How will the plating be attached to the frame - tack welding, rivets or bolted on?
How are you going to seal the canopy against leaks?
How do you cope with the different expansion and contraction rates between steel tubing and aluminium?
Harold (Greytown, KZN)
- Real Name: Jose
I will accept any advice on what works and doesn't.
The plan is to use 2mm thick alu.
will be using rivets (stainless steel)
will be using a silicone sealer
will find out about differrent expansion rates when its all done, but don't see an issue if I rivet.
- Bushwacker
- Town: Vryheid Natal
- Real Name: Piet
How bout using thin double-sided tape with the rivets, it should stop all rattles
Could be useful to use that wind seal foam, with sticky tape the one side, having this between the frame and alu sheets will stop rattles, the foam seal comes in rolls with various widths and thicknesses, then use decent silicone as well to waterproof the joints/seams...
B
B
Expansion rates are not a problem, use rivets. Don't use any foam type tapes or such like inbetween, they are not water tight and tend to in fact hold water, thus promoting rust on the frame. Use acetic silicone sealant which will also stop any rattles.
Years(many ) of wisdom have spoken... thanks Andy I'll bear that in mind when I get to build a canopy one day!
B
B
- Real Name: Jose
Thanks for all the info so far, don't stop, just a pity that I have to wait until the weekrnd to carry on with the canopy.
Presently sitting at the Southern Sun in Maputo by the pool side looking out onto the bay.
Shame... :evil:
- Town: Howick
- Real Name: Harold
Was at Ithala earlier this week and met a fellow who had made himself a canopy.
He had used Tectane 1030 as a sealant – apparently very good. Available from Ben Braven http://www.denbraven.co.za Well worth having a look at the product.
Den Braven products are definitely good, normally superior grade stuff, but sometimes not readily available. A sealant is far better for this application than double sided tape (even the outdoor grade which is a thin rubber, not foam). Tapes don't take up inperfections in joints and welds, whereas the sealants do. Why I suggested acetic silicone (or one also suitable for metals) is because they're relatively inexpensive, readily available at any hardware outlet and do the job.
- Scooter
- Town: JHB
- Real Name: Scott
Dont forget that a few guys have built there own canopies on this forum.
Check this out for a few ideas: viewtopic.php?f=41&t=325
IIRC the BAAS (Pietpetoors) used Sika Flex (not sure which one though) to secure the panels for his off road trailer, check this out :
http://www.pietpetoors.com/trailer/
- Real Name: Jose
Eish, picking the frame up from the powder coaters this afternoon, bought all the door rubbers, push button locks and gas shocks yesterday.
Today will take delivery of the aluminium chequered plate and a few other odd pieces and the mounting will start.
I want to mount the gas bottle holders on the outside of the canopy and have decided to build my own, has I am tired of laughing every time I enter an accessories shop and they quote me their prices, one favour to ask, anyone on this forum living around Benoni that is a pro at welding? That I can ask to weld the holders that I have made.
Will attach more pics tonight.
Cheers Jose
Cheers Jose
Why not do it yourself .... you did fine with the frame, and if it's stainless, just get a couple of stainless arc welding electrodes. They work well, just a bit dicey on thin material.anyone on this forum living around Benoni that is a pro at welding? That I can ask to weld the holders that I have made.
- Real Name: Jose
Naah I just have these visions of a number seven gas bottle rolling down the road cause my welding didn't hold.
- Niel
- Real Name: Niel
Sika 221 was used for the Alu canopies. I did not use pop rivets to attach the fixed panels only Sika 221 (glued)Scooter wrote:IIRC the BAAS (Pietpetoors) used Sika Flex (not sure which one though)
Sika make excellent products
- Niel
- Real Name: Niel
The 221 is a non corrosive adhesive for aluminum where as "normal silicone" will cause corrosion on alu.
Silicone is not just silicone, is not just silicone :D There are many different types for differing applications .. acetic is for use on metals, etches in. There are alkali's for wood etc., they are the more common variety and will cause corrosion on certain metals. Some silicone's are even hygroscopic, absorbing moisture and promoting rust on metal.
Read labels carefully before buying.
- Real Name: Jose
Ok here are the pic's as promised.
My first attempt at cladding ended up with me having fun with a 10 pound hammer, I made a mess but at least I felt better. :)
- DSC02436-1.JPG (45.57 KiB) Viewed 10424 times
- DSC02433-1.JPG (45.45 KiB) Viewed 10425 times
- DSC02429-1.JPG (42.31 KiB) Viewed 10427 times
- DSC02427-1.JPG (41.11 KiB) Viewed 10421 times
- DSC02425-1.JPG (46.03 KiB) Viewed 10424 times
Looking good
Very nice!!
I'm sure you'll keep us posted, nê!
It's looking great, Jose!
- Real Name: Jose
Ok basic canopy finnished and sort of ready for use this weekend?
- DSC02497-1.JPG (46.79 KiB) Viewed 10325 times
- DSC02530-1.JPG (48.35 KiB) Viewed 10324 times
- DSC02531-1.JPG (49.87 KiB) Viewed 10324 times
Looks very functional! I like the table door and the little gas rider stays!
Very neat work Jose
Could you give us your costings asblf man
- Scooter
- Town: JHB
- Real Name: Scott
Mooi man
What did you eventually use for sealing the plate?
- Real Name: Jose
I used acetic silicone and loads of poprivets. Luckily a mate of mine lent me his air operated rivet machine.
- falcon
- Town: Alberton
- Vehicle: HILUX S/C 4X4
- Real Name: Riaan
BUMP COST ????Dadz Toy BFI wrote:Very neat work Jose
- Town: Springs
Very nice Jose.The weight on the back wheels makes a huge diference when 4x4ing.
- Real Name: Jose
Will work out costing this weekend, now that I have time on my hands, but what I can say is that it will not be more than 6,5 K (that is including school fees).
L35, what is nice about the weight is that it has made the van a bit more level so when the fridge and water tank is installed I should have a perfectly level van.
- Spartan
Daai canopy gaan deur en deur die moeitewerd wees en vir die prys En wat gaan hy kos as jy vir iemand anders een bou terg net
MOBILITATE VINCERE
Spartan
Spartan
- Real Name: Jose
Ok here we go with the costs to build the canopy, this is for the basic canopy.
Steel R 800.00
Aluminium R 2522.00
Hinges x9 R 400.00
Locks R 970.00
Door Rubbers R 500.00
Gas shocks R 360.00
Odds&Ends R 500.00 ( Grinding disks/welding rods/pop rivits/silicone etc)
Powder Coating R 450.00 (Oops forgot to include )
Total R 6502.00
Steel R 800.00
Aluminium R 2522.00
Hinges x9 R 400.00
Locks R 970.00
Gas shocks R 360.00
Total R 6502.00
Six Grand well spentesajoda wrote:Ok here we go with the costs to build the canopy, this is for the basic canopy.
Steel R 800.00
Aluminium R 2522.00
Hinges x9 R 400.00
Locks R 970.00
Gas shocks R 360.00
Total R 6052.00
- Spartan
It is normally the labor that takes allot on the price
MOBILITATE VINCERE
Spartan
Spartan
Looks very good Jose, well done
- Real Name: Jose
Ok, had some spare time this weekend and so decided to give the Kitchen a go, here are a few pics just missing the Coffee mugs and the small Spice rack and of course a good varnishing.
- DSC03086-1.JPG (48.65 KiB) Viewed 8572 times
- DSC03087-1.JPG (47.45 KiB) Viewed 8572 times
- Niel
- Real Name: Niel
Jose, die kombuis lyk baie netjies
- Real Name: Jose
Ok, Canopy is finally ready for its first adventure trip.
Under the carpet is a 60L water tank and a hidden storage space.
Finally the kitchen is complete.
Last pic is the drawer syetem installed.
- DSC03090-1.JPG (46.45 KiB) Viewed 8543 times
- DSC03093-1.JPG (48.65 KiB) Viewed 8543 times
- DSC03094-1.JPG (45.65 KiB) Viewed 8543 times
- Niel
- Real Name: Niel
Jose, very nice and well done. 1 Question, is that beer for me
- Real Name: Jose
Thanks Niel.
I owe you a case if you take all the ideas I got from you. :) , when in Cape Town again.
- barleigh
- Town: Durban
- Vehicle: 1995 2.4P Toyota Hilux Raider Dbl Cab - 22R
- Real Name: Barend
Inspiring stuff.
You have definitely given me some ideas for my spare time and cash for the rest of the year!
Thanks for sharing.
Thanks for sharing.
- Thunder02
- Town: East Rand
- Vehicle: IFS Hilux
- Real Name: Neil
- Club VHF Licence: HC105
Very well done, like the way you've used the space.
Scout motto:be prepared....
www.4x4direct.co.za
www.4x4direct.co.za
- CMK
- Town: Ficksburg
- Vehicle: Toyota Hilux 3L D4D 4x4
- Real Name: CM
I must say that this is well done! Im busy building a canopy for my d/cab Cruiser and it takes a lot more thinking and the correct execution to get it all correct.
CM Kotze
- Obelix and Dogmatix
- Town: ROODEPOORT
- Real Name: Quentin
Jose you lie!!
That is not an attempt!!!
God made man before
woman so as to give him time
to think of an answer
for her first question.
God made man before
