2003 Hilux 4x4 front driveshaft CV joint repair kit.
Posted: Tue Jun 13, 2023 9:51 pm
The front driveshaft ( the one between the transfer case and the front differential) in my '03 Hilux 4x4 clunks like crazy when the truck is in 4wd. I removed it, and the 3 ujoints in it are toast. I took it to my mechanic and he said the entire driveshaft must be replaced. Tried other mechanics and got the same response. Here's what the shaft looks like:
The cv joint is in the "H" yoke. It consists of a ball and a rod separated by a spring. The spring in my truck is broken off. Buying a complete new driveshaft costs over $700 dollars, and I've not found one available anywhere. I have a set of replacement u-joints. Do you guys know of a replacement CV joint kit ?? Or ... should I just install the new u-joints and go for it?? I seldom use 4wd. Only to get through deep mud or up steep hills. Never over 5 mph.
Opinions ???
James
Opinions ???
James
