Lumeno System - Male Connectors
oxydog
Vehicle: '98 Hilux SFA 2.8D 4X4 D/C, '06 Hilux 4.0 V6 4X4 D/C
Real Name: Jarus
Club VHF Licence: J67
Post by oxydog »
Hi all,
I've built myself a small Lumeno system for lights in the tent and trailer. I have a couple of 12V 7Ah batteries, the Lumeno battery buddy with charger and lighter plug extension, some cables and some lights.
My question is: Is the connector from the 220V Trickle Charger that goes into the battery buddy the same as the male DC connectors on the cables? If so, is there any reason why I can't use the 4-way splitter on the charge port of the battery buddy to run my lights from?
Bees (Toy)
'98 Hilux 2.8D 4X4 D/Cab
• ARB Bullbar
• Safari Snorkel
• GearMax Rear Locker
• Front Runner bakkie slide
• 31" BFG KM2's
'06 Hilux 4.0 V6 4X4 D/Cab
• Level-it kit (Front)
• Custom integrated bullbar
• Custom replacement bumper
• Midas driving lights
• 31" BFG KM3's
pieta.swanepoel
Vehicle: 2017 Toyota Hilux 2.4 GD-6 SR 4x4 SC
Real Name: Pieta
Re: Lumeno System - Male Connectors
Post by pieta.swanepoel »
Maak net seker jy meng nie 220V en 12V nie. Die in van die charger is 220V en die uit 12V. Jy kan in en uit meng solank alles net die selfde volts is.
In my battery stelsel meng ek DC-DC, solar, CTEK charger en al die uitsette op dieselfde lyne. Alles is 12V.
oxydog
Real Name: Jarus
Post by oxydog »
pieta.swanepoel wrote: Sat Nov 05, 2022 11:35 am Maak net seker jy meng nie 220V en 12V nie. Die in van die charger is 220V en die uit 12V. Jy kan in en uit meng solank alles net die selfde volts is.
Dankie vir die raad Pieta. Ek verstaan darem AC en DC (elektroniese ingenieurswese help bietjie ;-) ), is net nie seker oor die connector se specs nie.
Bees (Toy)
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
dax021
Town: Harkerville WC
Vehicle: 1990 Hilux 4Y
Real Name: Peter
Post by dax021 »
Your question is rather confusing, to me at least. I have no clue what a Lumeno system is, so maybe try posting a pic or two. You say you have electrical engineering knowledge, this should be a walk in the park.
oxydog
Real Name: Jarus
Post by oxydog »
dax021 wrote: Mon Nov 07, 2022 8:42 am Your question is rather confusing, to me at least. I have no clue what a Lumeno system is, so maybe try posting a pic or two. You say you have electrical engineering knowledge, this should be a walk in the park.
My apologies, I made certain assumptions that I shouldn't have.
Lumeno makes plug and play type 12V camping lights, cables and connectors.
Example of a light:
https://www.lumenoled.co.za/product/12- ... ite-amber/
Connectors are 12V male/female, eg. this splitter:
https://www.lumenoled.co.za/product/4-way-splitter/
They also make this "Battery buddy" with charger for charging from 220V and connecting to your 12V lights:
https://www.lumenoled.co.za/product/battery-buddy/:
I just want to know if the connector for the charger and the male connectors on the splitter are identical, as I would like to also feed the lights from the charging port of the battery buddy (and not only from the lighter socket).
I hope that's more clear than my previous attempt.
Bees (Toy)
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
dax021
Real Name: Peter
Post by dax021 »
No need to apologize. I would guess that one of the split cables will be the correct size. I reckon the best way would be to go to a shop that sells these and test for fitment.
I bought this from my local China shop for R25. Works like a charm, and the 4 way plug fits everything.
oxydog
Real Name: Jarus
Post by oxydog »
dax021 wrote: Mon Nov 07, 2022 9:43 am No need to apologize. I would guess that one of the split cables will be the correct size. I reckon the best way would be to go to a shop that sells these and test for fitment.Cable.jpg
That's a neat idea. Inline fuse, the works!
Bees (Toy)
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
oxydog
Real Name: Jarus
Post by oxydog »
Update: The splitter with 1 female and 4 male connectors works 100% as a means of supplying 12V from the female (charge) port of the battery buddy!
Bees (Toy)
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
dax021
Real Name: Peter
Post by dax021 »
Great, always good to hear that a plan has worked as intended. Post a pic or two for interest sake
oxydog
Real Name: Jarus
Post by oxydog »
dax021 wrote: Thu Nov 24, 2022 8:11 am Great, always good to hear that a plan has worked as intended. Post a pic or two for interest sake
Geez Peter, as I was packing all the crates away I thought "Damn, should've taken a pic for the Forum!" :laugh2:
Will do tonight or over the weekend!
Bees (Toy)
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
oxydog
Real Name: Jarus
Post by oxydog »
As promised! Image
Sent from my SM-F926B using Tapatalk
Bees (Toy)
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
