Hilux no 4x4 working
Posted: Mon Aug 15, 2022 11:55 am
Hi all.
My toyota hilux 2006 4x4 2.5 d4d is giving me grey hairs.
So a bit of history leading to this find.
February the vehicle went in for a flashing 4x4 light (the little one with the wheels turned). 4x4 was still working even with this flashing light story. Got it back light was off. Was told a switch on the box was changed. Cool...
Next day had front diff oil seals done, cv boots replaced and new sideshafts fitted. All good.
To my mistake I never tested the 4x4 after this. Before the services it was working.
Fast forward to July the light starts flashing again randomly in the traffic not touching the 4x4 at all.
When I got home I engaged 4x4 and nothing happened.
So jacked the back diff up so the wheels where off the ground. Engage 4x4 1st gear clutch out. Front wheels dont pull the trolley only back wheels turn.
Low range engaged same story. If I'm in low and push the read diff lock i hear it click in so back lock is working. I had a look and the front driveshaft is turning but nothing to the wheels.
Check all the fuses under the dash passenger side. All good. Relay clicks.
Trace all the wires no breaks all looks good.
Where do I go from here. Iv disconnected the front actuator plug what pin do I test to see power? As currently I dont see any 12v on and pin...
Could it be a switch on the box? If so that one do I check?
Thanks guys please any assistance will help.
