Hi everyone, does anyone know where to look if the rear diff lock on my 2007 D4D Hilux is not engaging, the indicator light in the cluster is illuminating when I depress the diff lock switch, but the diff lock does not operate.
I have had a diagnostic done, but the diff lock circuit does not feature.
Any assistance would be most welcome.
Regards.
Chris Joe.
2007 Hilux rear diff lock not engaging
- Town: Vryheid
- Vehicle: 95 hilux d/c Hilex
- Real Name: Wimpie Van Der Vyver
Re: 2007 Hilux rear diff lock not engaging
Chris check the wiring from difflock motor where it meets the chassis had a couple that was broken of there.Cut and remove the corregated sleeving and gently pull on eatch wire.
- Tristin
- Town: East london
- Vehicle: Toyota hilux
- Real Name: Tristin
- Club VHF Licence: HC359
Hi Chris I had the same situation with my hilux kzte, after many hours I eventually pulled the electric motor off the diff.The internals of the motor were badly corroded and I ended up replacing the unit.
