I want to install a limited slip center section in my '03 Hilux 4 x 4. But I have no idea what type of rear axle is installed in my truck. I have looked online at photos of different Toyota 4 x 4 rear axles, but none match up with mine. All trucks sold in Colombia are 1 ton rated, so maybe this is part of the problem. Here are some photos.
Anyone know the model number of this guy ?? Thanx in advance.
- JAMES
IDENTIFY THIS
Re: IDENTIFY THIS
Hi James,
Can you maybe post a picture from the rear of the diff?
Maybe type your vin into toyodiy.com and see if you can see the spec there?
Re: IDENTIFY THIS
Looks like it's the standard Toyota diff that was used in the 2.2 / 2.4 petrol and 2.4 / 2.8 diesel models. LSD kits were (and probably still are) available for these diffs.
- Town: Alejandria Antioquia Colombia SA
- Vehicle: Toyota Hilux 4x4
- Real Name: JAMES
Re: IDENTIFY THIS
Thanks Mud. I checked and you are right. I'm contacted a shop and set up an appointment for them to rebuild the center section and install a Limited Slip unit.
- JAMES
- JAMES
