LJ70 Shorty 2LT vs LJ72/3L and engine swap options
Posted: Mon Oct 19, 2020 9:47 am
Good morning all ,I have been a lurker on this forum for years and thanks to you all I have got a huge amount of value.
I work up in Uganda where there is a large selection of 1980's and 1990's Toyota 4x4s of all shapes and size.
Cars and spares are easy to come by and fairly well priced ,you would all be like kids in a candy store !
Here is the question ....I have found two shorty land cruisers for sale the first is an LJ73 with a 2LT turbo diesel and an R151f transmission in good nick.
the second is a rare LJ72 with a 3L motor and the four speed G40 gearbox with the prado grille.
if I was to by the LJ72/4speed I would most likely just leave sleeping dogs lie and put up with the slow reliability of that combo.
if I was to go the LJ73 /2LT route I am nervous of this engines head cracking and (even though it looks ok and the body is light)
what would the collective wisdom be on an engine replacement be on this car if I was to swap ?
as I see it the options would be as follows.
3RZ FE-strong .reliable available and small enough for the engine bay .Questions on the gearbox fitting without modification and fuel consumption.
Kzte-some people are afraid of the heads ,lots of power, easily available .Gearbox compatibility?
1HZ-overkill on size and weight on the front axle .non turbo reliability is good
1PZ -may bolt straight onto the gearbox and will be shorter and a little lighter than the 1HZ.easy spares and non turbo reliability but relatively unknown.
1KD- sexy as hell ,lots of power ,electronics complications, expensive?
ideally i would like to use the car mostly for overland and it will continue to live in the third world.
I am leaning to the 1PZ as it is not popular in the large cruisers and I could potentially pick one up for cheap. I also suspect that the conversion may be the simplest option and give me good, long ,reliable service.(i may have to change the fly wheel from the Dual Mass standard on the 1PZ)
i have not spoken about the LJ72/3L car much but it was owned by an aircraft mechanic and although it has 350k on the clock it is in relatively good condition .if anyone has a rush of blood to the head and has swap suggestions for it ,feel free to go for it!
I am leaning toward the LJ72 ,its a great little car and it looks ok for its age.
Your Thoughts?
Your Thoughts?
