Headlight adjustment
schalkjk
Vehicle: Hilux Legend50
Real Name: Janus
Post by schalkjk »
Hi all
Have anyone been able to adjust the Legend50 headlights hight? Its just that inch or so too low. At night it doesnt give sufficient light ahead. I know the headlights are auto leveling that will adjust the hight when you have a loaded bin. I just need that bit more even when unloaded.
It becomes an issue when cruising at speed and not being able to go to high beams.
guidance would be appreciated
schalkjk
Real Name: Janus
Re: Headlight adjustment
Post by schalkjk »
Asked my dealership if this can be adjusted like the older vehicles.
There are small little screws that will adjust the hight of the low beam.
Hi Janus, All headlight must be adjustable both vertically and horizontally. It just gets confusing at times which screw does what.
Perhaps you can post a pic of the adjustment scews so that other users with the same model vehicle can benefit from your learning curve. :winkx:
schalkjk
Real Name: Janus
Post by schalkjk »
Sure no problem.
I can only show the vertical adjustments.
Its not a screw, but rather a gear. See attached photo and short video.
All you need is a philips head screw driver to be able to create a cog in the gear to adjust the lights up or down(Clockwise & Anti-Clockwise).
Unfortunately it seems I cant upload the short clip to show the action
Thanks Janus. Looks like they like using this idea in the later Toyota's ... My Rav has the same.
schalkjk
Real Name: Janus
Post by schalkjk »
Yes
Seems like its the LED auto leveling Headligts in the more recent Toyotas
