Rough idle 2012 3.0 D4D auto
Posted: Sat Apr 11, 2020 9:40 am
Hi guys. We moved to the UK 3 years ago and after a rough ride in a MazdaCX 5, I’m back in my beloved Hilux. I have the 3.0 auto D4D which I look forward to getting into each day except for:
When she’s warm, she experiences rough idle when in drive or reverse. This is to say, when I arrive at a robot and stop, the engine idles irregularly like it is on the verge of stalling( it never does stall). If I slip it into neutral she returns to normal idle. She drives beautifully. Fuel consumption seems normal and other than the rough idle under load, I can’t fault her.
The following has been replaced:
Egr valve
Engine coolant temperature sensor
Maf sensor
Diaphram filter on map sensor
Throttle body
There are no apparent air leaks on the intake side. The fuel injectors have been removed and tested by Bosch approved workshop and all ok. It’s such and insignificant issue but a huge irritation.
Any thoughts or suggestions?
Egr valve
Maf sensor
Throttle body
