Finally got round to fitting Spitronics to my Lexus Hilux
DANIELK
Town: Randburg
Vehicle: Toyota Hilux 1990 DC V8
Real Name: Karl
Post by DANIELK »
After having endless issues with the wiring on the OEM ECU, Some of the Issues:
1. Felt like you hit Rev Limits at 3500rpm
2. Getting Hesitation
3. Bad Fuel Usage
4. No Power
Im sure the computer was in Limp Mode, it was getting bad was about to :surrender: ( brought it with the original ECU in). Just about replacing every dam sensor lol. So I went and purchased the Orion advance ECU the 1UZFE non vvti kit R 5400.00. It seemed very straight forward, had no major issues at all doing the change, also gave me time to take out all the other doggy wiring from perv. Owners as well. After installing it turned the key 🔑 she purred wow 😳 I was amazed at the difference. Took 2 days off work and started the job 4 days later she was great again.
Starting the job
Starting the job at hand
This is just before old harness came off . The previous owner had the computer in the engine bay, in a steel box that was rusty and messy.
Just before removing old Lexus harness
What she looks like now, ECU is in side the cab now, lot less wires now
:yahoo:
The Hilux
What the motor sits in
She is running great again
Regards
Karl
Trucks
1990 Toyota Hilux DC 4x4 4.0 V8 1UZ-FE (Current)
1998 Ford Courier SC 4x4 3.4 V6
2001 Ford Ranger DC 4x4 2.5 TD
1996 Ford Courier DC 4x4 3.4 V6
Re: Finally got round to fitting Spitronics to my Lexus Hilux
Awesome. Good to hear you got it sorted. :thumbup:
Did you do a dyno?
DANIELK
Town: Randburg
Real Name: Karl
Post by DANIELK »
Not yet, I want to get through to power flow to get them to look at the exhaust first, I did try and get hold of the guys in kempton park RBTS, will try and get round to it early April...
Regards
Karl
Trucks
:thumbup: It's a "must do" so don't leave it too long. Chances are very small that the base map is running too lean but if it is you can burn valves. :winkx:
