Checking Gearbox Oil level - Hilux 3.0D4D
Darkwing Duck
Vehicle: Hilux 3.0 D4D
Real Name: Ferdi
Good day
I want to check the gearbox oil level on my Hilux 3.0D4D
Any special tool to be used to remove the filler plug?
Last edited by Darkwing Duck on Wed Dec 18, 2019 10:40 pm, edited 1 time in total.
Isn't there a dip-stick for the g-box against the firewall? Not sure of this myself and don't know the vehicle, just thinking that I remember someone talking about it some time back. :think:
Darkwing Duck
Real Name: Ferdi
I found the filler plug, it is on the top/left hand side, but a 24 mm socket or spanner does not do the job
Toyota SA said it's a special tool to loosen the plug.
I feel like loosening the bolt, my way, but then i need to replace it. Just afraid I might brake something somewhere.
Even the gearbox cooler is to close for comfort, lack of space to use a bit of moering power.
(R58 for new plug/bolt)
Anyone that had the same issue with spanners/sockets that does not fit on filler plug?
And if you are a DIY boytjie, how did you do yours?
Jaws
Town: Sharonlea
Vehicle: 2009 D4D 4x4
Real Name: Herman
I have opened my before. But the plug is very soft and I have replaced it in the past as the corners got rounded a bit
Sent from my ELE-L29 using Tapatalk
:thumbup:
