Crack in top tank of radiator
- GTO
- Town: Fish Hoek
- Vehicle: 2002 2700i 4x4 DC ; 1995 2.4 SRX
- Real Name: Stephen
I came home and noticed pink coolant under my 2002 2700i Hilux, the top tank of the radiator has a fine straight crack a 10cm long about midway on the engine side.
It took me a while to figure out where it was leaking but if squeeze the bottom hose I can see the coolant coming out of the crack.
Can this plastic tank be fixed by a radiator repair shop or is it better to get a new radiator?
1985 Suzuki DR600S
1984 Honda ATC200ES BIG RED
1985 Suzuki DR600S
Re: Crack in top tank of radiator
Not fixable.
Shop around for a new radiator BUT first measure the thickness for the existing one's core. Take a thin wire and push is through the radiator until you can feel it on the other side. Now extract and measure.
Make sure you get the same or thicker radiator - thinner one will at some point cause overheating.
- GTO
- Town: Fish Hoek
Thanks for the tip.
Probably going to buy from Radiator King, I have bought from them before and their service was very good.
1985 Suzuki DR600S
1985 Suzuki DR600S
- Bear
- Real Name: Ricky
Plastic can be welded. Depends on the workmanship of how good it will hold. For the sake of reliability I suggest to get a new one.
Radiator King seems to be a specialists in radiators, by the name. Phone around to the local spares shops. You may just get it cheaper.
Regarding Thabo’s point. They are cores. There is a three core, four core etc. Take a sample if possible.
Extra cores provide much more efficient cooling, no disadvantage. Less cores = to what Thabo said.
- GTO
- Town: Fish Hoek
They have 2 types a Genuine one and a cheaper aftermarket one.
Genuine is R 3190 and aftermarket R 1490.
I have ordered the Genuine one will collect later today.
I am taking my old radiator with me to compare.
1985 Suzuki DR600S
1985 Suzuki DR600S
- GTO
- Town: Fish Hoek
Radiator King reckon the top tank is more prone to cracking due to hot water input there.
My top tank is a different colour to bottom one, bottom is black top brown colour?
1985 Suzuki DR600S
1985 Suzuki DR600S
- Bear
- Real Name: Ricky
While the radiator is out do a good flush through the block with a hose. Check if the thermostat is still good, no corrosion, the rubber seal is ok. Use a genuine antifreeze, preferably the Toyota one. The ones from Auto Zone and Midas are not good.
- GTO
- Town: Fish Hoek
Installed new radiator yesterday late afternoon during load shedding!(no point sitting at the office doing nothing)
I have used the Toyota coolant for years now after reading about how good it was on this forum, I rarely have cooling system issues since switching to it.
1985 Suzuki DR600S
1985 Suzuki DR600S
- Bear
- Real Name: Ricky
I hope all is right now.
- GTO
- Town: Fish Hoek
1985 Suzuki DR600S
1985 Suzuki DR600S
- GTO
- Town: Fish Hoek
Last night i decided to strip off the tanks of the old radiator.
PIC 1:
Inside of top tank(bottom one in pic) is white powdery in colour also spout where hose goes on is brittle I scrape the plastic away with my finger nail!
PIC 2:
Crack in top tank where it was leaking.
PIC 3:
Colour difference of outside plastic is very noticeable, brown for top tank(bottom one in pic) and black for bottom tank.(new radiator both tanks black).
PIC 1:
PIC 2:
PIC 3:
1985 Suzuki DR600S
1985 Suzuki DR600S
