Happy new Prado owner - which shocks to fit ? (need advice please!)
Posted: Thu Nov 16, 2017 9:42 pm
Hi guys!
My 2002 Prado appears to still have the original shocks fitted (after 400 000 kms!!) They urgently need replacement. The suspension is still standard and has not been "lifted" - because of that, the local LA Sport can't help me because they only fit TJM shocks for "lifted" suspension, which would not work on mine. Finances are a bit limited so I can't go the most expensive route - which shocks would be suggested?
Got a quote on Iron Man shocks, but +R11 000 sounds a bit (and is definitely !) excessive and above my budget.
I had a discussion about the Monroe Ranchero range - apparently the "premium" heavy duty" off-road version for the LWB vehicles, and also adjustable with 8 or 9 different settings. (awaiting quotes on these but it might be in the region of about R6k-R7k) I am also told that the standard heavy duty Monroes would not last, and that Gabriel does not offer any suitable solution ?
Any suggestions or advice from the wise men out there ? Options in Mossel Bay and George are fairly limited...
