Torsion bars on ifs
- Town: Port Elizabeth
- Vehicle: 2000 kz te 2x4
- Real Name: Andries
- Club VHF Licence: N/a
Torsion bars on ifs
Hi guys
Need help with instaling and setting torions bars on my 2000 model hilux single cab.kz te 2X4.
Tried everything and bakkie still have no suspension
Please help
Please help
Re: Torsion bars on ifs
I'm not familiar with the IFS suspension intricacies but if it's properly fitted you will have to take the weight off the front wheels (jack it up) and torque up the tension on the torsion bars, same number of clicks on each side. I don't know what the torque specs are, but you can do it by trial and error - take it up one or two clicks at a time after the initial torquing until it stands level. Perhaps someone that knows can be of further assistance.
Thank you. Done all the setting up and down.still rock hard
disconnect shocks even stabiliser bar.even took the brackets up one notch on the splines of the bars
Ps.all upper, lower bushes,upper, lower balljoints.inner outter tie rod ends, idler arm, pitmam arm and shocks replaced new.not yellow poly bushes.
Disconnected torsion bars to check upper and lower control arms for seizure. No luck.
Driving me crazy
Driving me crazy
I see .... so you don't have the problem that it sits right down but the opposite (no suspension movement).
I was going to suggest that you remove the shocks and see what that does, but I see you've already tried that. Can you move the control arms up and down when the stabilizer / torsion bars are disconnected?
- WayneSchalk
- Town: Krugersdorp
- Real Name: Wayne
- Club VHF Licence: X117
Perhaps give Darryl a call @ Mikem Suspension. I am sure he can give some good advise
@mud dog.yes.i disconnected everything in order to see if I havnt press the bushes in the wrong way causing the control arm not to move freely.
@wayne
Will do.where are they based? Perhaps a contact number.
@wayne
Thanks guys for the advice.
The torsion bars is no more. Kaput. Ism.
After a lot of up and down came to the conclusion that the bars has solidified did not know it could.
Have 2 new ones on order from Toyota @1100 each.
The factory producing torsion bars for OME is in Nigel - and they sell to the public!
Awesome thanks.
Peharps a name for the company?
If I remember correctly, Spring Supreme.
Yes found them online. Not much cheaper than the agents.
- Vehicle: Hilux 2.7i
- Real Name: Michael
I have a set that are as good as new. PM me if you are interested
Hi please send me your number
0eight34two56zero17
