Ctek 250S Dual
- pietdevs
- Town: Mosselbay
Ctek 250S Dual
I have a CTec 250S dual in my bakkie as a dual battery system. I can connect a solar panel to the Ctec which is no problem. Can I connect 2 solar panels to the Ctek terminals - it has different power deliveries. The one is 75 Watt and the other is 100 Watt. I will appreciate your comments
Re: Ctek 250S Dual
Pieter I have connected two similar panels in parallel.
I have been told that it is not a good idea to connect dis-similar panels together, not in series nor in parallel ...
- pietdevs
- Town: Mosselbay
Re: Ctek 250S Dual
I thought so! Wat nou? Werk joune reg Chris?
Re: Ctek 250S Dual
JIP, met soortgelyke panele in parallel werk die Ctek perfek.
- Cinco
- Town: Marloth Park
- Vehicle: Hilux Vigo
- Real Name: Ian
- Club VHF Licence: HC243
Re: Ctek 250S Dual
I had two fold up 80W (40 + 40) and I broke one half on one of them about three years ago. Since then I have been running them in parallel (80 + 40) through a ctek with no problem. Ignorance is bliss.
Wishing my life away till the next trip!
- Lomies
- Town: Centurion
- Vehicle: 2013 3.0 D4D D/C 4x4 Hilux
- Real Name: Arné
- Club VHF Licence: HC273
Re: Ctek 250S Dual
Ek het ook twee son panele wat ek saam op koppel op my ctek. Die een is n 150w en die ander een n 80w. Altwee is dieselfde maak. Dit werk goed.
Re: Ctek 250S Dual
Thanks gents. So much for the old wifes tales of dis-similar panels ....
Re: Ctek 250S Dual
Parallel connection with two dissimilar panels should be no problem, but for series connection they should be identical, otherwise they will only work as well as the smallest one.
- Town: Centurion
- Vehicle: Fortuner 4x4
- Real Name: Frank
Re: Ctek 250S Dual
Hallo julle ook net gou n vraag. Ek het ook n 250 Dual maar net met een Soarce terminaal, dis nie soos die nuwes wat 2 het nie. Kan die soarce van die altenator en n son paneel gelyk wees of kan jy net een op n slag as soarce gebruik
- Thunder02
- Town: East Rand
- Vehicle: IFS Hilux
- Real Name: Neil
- Club VHF Licence: HC105
Re: Ctek 250S Dual
Hi, You can't join the alternator and solar panel onto the same terminal. The unit will not be able to handle it.Foksie wrote:Hallo julle ook net gou n vraag. Ek het ook n 250 Dual maar net met een Soarce terminaal, dis nie soos die nuwes wat 2 het nie. Kan die soarce van die altenator en n son paneel gelyk wees of kan jy net een op n slag as soarce gebruik
Scout motto:be prepared....
www.4x4direct.co.za
www.4x4direct.co.za
- Town: Centurion
- Real Name: Frank
Re: Ctek 250S Dual
Ok Thanks
- Cinco
- Real Name: Ian
Re: Ctek 250S Dual
That sounds like the SMART PASS (3 terminals)and not the dual?
- WayneSchalk
- Town: Krugersdorp
- Real Name: Wayne
- Club VHF Licence: X117
Re: Ctek 250S Dual
Nope, you do get the older one that was only a DC-DC Ctek 250s that had 3 terminals, you cannot connect a solar panel, the later version is the dual with 4 terminals where you can connect the alternator and a solar panelCinco wrote:That sounds like the SMART PASS (3 terminals)and not the dual?
- mushroom
- Town: krugersdorp
- Vehicle: '16 Legend 45 DC 4x4M
- Real Name: James
Re: Ctek 250S Dual
IIRC - the maximum input votage is 23V - so you must connect in parrallel if they are big panels.
Q20 if its stuck, duct tape if it moves
- Johan Kriel
- Town: Okahandja
- Vehicle: 2.5 SC 4x4
- Real Name: Johan kriel
Re: Ctek 250S Dual
Max 20 amps of course.
In series is not possible with the ctek 250, as said the max volts is the limitation.
But otherwise if the amps are more or less the same one can use it in series, but the output is as said that of the lowest one. In parallel, if the volts are not the same the volts will settle somewhere in between and gives more or less the combined amps.
Johan Kriel
Legend 50
Legend 50
- Town: Centurion
- Real Name: Frank
Re: Ctek 250S Dual
The Manual refers to a supply does that mean only a altenator or can the the supply be from solar as well.WayneSchalk wrote:Nope, you do get the older one that was only a DC-DC Ctek 250s that had 3 terminals, you cannot connect a solar panel, the later version is the dual with 4 terminals where you can connect the alternator and a solar panelCinco wrote:That sounds like the SMART PASS (3 terminals)and not the dual?
- WayneSchalk
- Town: Krugersdorp
- Real Name: Wayne
Re: Ctek 250S Dual
Hi Frank,Foksie wrote:The Manual refers to a supply does that mean only a altenator or can the the supply be from solar as well.WayneSchalk wrote:Nope, you do get the older one that was only a DC-DC Ctek 250s that had 3 terminals, you cannot connect a solar panel, the later version is the dual with 4 terminals where you can connect the alternator and a solar panelCinco wrote:That sounds like the SMART PASS (3 terminals)and not the dual?
jy het mos die een wat net 3 terminale het? Indien so kan jy net van die alternator af op koppel, die met 4 terminale het 'n ingeboude MTTP solar regulator.
- Town: Centurion
- Real Name: Frank
Re: Ctek 250S Dual
Baie dankie ek verstaanWayneSchalk wrote:Hi Frank,Foksie wrote:The Manual refers to a supply does that mean only a altenator or can the the supply be from solar as well.WayneSchalk wrote:Nope, you do get the older one that was only a DC-DC Ctek 250s that had 3 terminals, you cannot connect a solar panel, the later version is the dual with 4 terminals where you can connect the alternator and a solar panelCinco wrote:That sounds like the SMART PASS (3 terminals)and not the dual?
