Recovery off rear bumper bracket
StuckInTheMudd
Town: Durbanville
Vehicle: Hilux 3.0 D-4D Xtracab 4x4
Real Name: Greg
Post by StuckInTheMudd »
I need to replace my rear bumper to add recovery points and to add some protection. I currently have the standard tissue paper installed.
I'm thinking about building my own bumper. Will my current brackets be strong enough to perform recovery off?
They look something like this...
Full Size
Dowe Koos
Real Name: Hennie
Re: Recovery off rear bumper bracket
Post by Dowe Koos »
For myself, I rather have a 8mm thick plate than these on your photo.
StuckInTheMudd
Town: Durbanville
Real Name: Greg
yea i'm kinda doubtful as to their strength. where could I get something better in the Northern Suburbs?
niclemaitre
Town: Stellenbosch
Vehicle: 99 IFS DC 4x4
Real Name: Nic
Post by niclemaitre »
Get 8 or 10mm plate laser cut rather
Happy trails
Nic
SFA '87 DC "Rooies" - sold
IFS '99 DC "Benny"
StuckInTheMudd
Town: Durbanville
Real Name: Greg
that's not a bad idea. how much does that cost?
niclemaitre
Town: Stellenbosch
Real Name: Nic
I had something similar made up for my front bumper and both identical brackets came to around R350 total. You can then weld spacers around the recovery hole in the bracket to make it more resistant to being torqued.
Third pic down is the bracket I had made: viewtopic.php?f=41&t=39900&p=472088#p472088" onclick="window.open(this.href);return false;
If you can make the diagram yourself in SketchUp or some kind of CAD it will be cheaper than if you give them the existing bracket and they have to do the drawings themselves.
Happy trails
Nic
IFS '99 DC "Benny"
StuckInTheMudd
Town: Durbanville
Real Name: Greg
that looks pretty decent. i'm concerned about matching the existing holes in the chassis to the drawing though. or should I rather drill the holes myself?
Jurgen10
Vehicle: 2009 Hilux 4.0 V6 Raider DC 4x4
Real Name: Jurgen
Club VHF Licence: HC239
Post by Jurgen10 »
Dowe Koos wrote:For myself, I rather have a 8mm thick plate than these on your photo.
+1 thousand , million, seventy five hundred and two
Please do not use the standard tissue paper bumper fittings , they are almost as thin as the bumper and will fail when you don't want them to.
I used the standard fittings as a template to drill the holes on the 50 x 50 x 5 angle iron I used for brackets when bulding my rear bumper, and I don not intend using the 5mm brackets as recovery points... their job is just to hold the bumper up :)
viewtopic.php?f=41&t=40806&p=480536#p480536" onclick="window.open(this.href);return false;
StuckInTheMudd
Town: Durbanville
Real Name: Greg
Who knew that when one buys a 4x4 it becomes a big boy's Mekano set :mocking:
I intend on using something of substantial girth. Also want to double-up, put a bracket on both sides of each chassis beam.
niclemaitre
Town: Stellenbosch
Real Name: Nic
StuckInTheMudd wrote:that looks pretty decent. i'm concerned about matching the existing holes in the chassis to the drawing though. or should I rather drill the holes myself?
Measure carefully with a vernier. They will most likely be some whole number in mm apart. The centers will be the distance between the holes plus one hole diameter apart.
It's more the shape that you should worry about since it is shaped like that to avoid various fittings etc.
Happy trails
Nic
IFS '99 DC "Benny"
niclemaitre
Town: Stellenbosch
Real Name: Nic
SketchUp is damn easy to use if you spend a little time figuring it out. There is a plugin for the free version that exports to .dxf files that the laser cutters use. All the time I've invested in learning how to use it properly has been repaid many times.
Happy trails
Nic
IFS '99 DC "Benny"
Use 8mm plate, minimum. Reinforce the recovery holes - this can be done by welding a short (about 12mm) piece of thick wall pipe into an oversized hole. You should also weld a reinforcing gusset (with appropriate holes) over the rear chassis rail legs - all good and well to beef up the bumper mounting brackets but then the weak point becomes the chassis rails - they're only about 2½mm gauge on those extensions and I've seen those holes tear / elongate first hand. Also use suitably rated bolts. :winkx:
StuckInTheMudd
Town: Durbanville
Real Name: Greg
ah yes. good advice.
perhaps a stupid question, are steel square bars strong enough for recovery purposes?
and would filling it with sand be a good idea? I want to destroy anybody riding into me :)
Don't recover off the bumper itself - use the brackets for that. The 'danger' in beefing up the bumper rails is that there will be little or no 'give' on impact and the damage will transfer into the chassis. It's also unnecessary weight on the rear overhang. Use something like 2mm - 2.5mm gauge but brace the section between the mounting brackets from behind if you're going to tow with it.
StuckInTheMudd
Town: Durbanville
Real Name: Greg
Mud Dog wrote:Don't recover off the bumper itself - use the brackets for that.
oh right! Is there any need for those rated recovery hooks/points then?
Mud Dog wrote:The 'danger' in beefing up the bumper rails is that there will be little or no 'give' on impact and the damage will transfer into the chassis.
You've got a point there. That got me thinking. There are shock absorbers for bumpers. Worthwhile? Or am I getting to complex now?
Town: inniedorp
Vehicle: Toy
Post by ChrisF »
Friend owns a panelbeater workshop.
He has built MANY custom rigs over the years.
Bracket from the chassis rail - THICK steel, attach your recovery points at this point. Firstly it is the strongest point, secondly it is directly in line with the chassis rail, thus no bending and twisting
from there his bumpers are a "measily" 2mm steel. Way thick enough for light bumps, but it is still the soft part that absorbs a mild impact - thus protecting your vehicle !
Remember in a mild to heavy accident something WILL bend. If your bumper is too strong it will be the vehicle doing the bending ....
Changes
Vehicle: Fortuner
Real Name: William
Club VHF Licence: HC 285
Post by Changes »
Just fit a Bundu Gear bumper from Neil at 4x4 Direct and all issues and problems solved.... :-)
Do not BRAND bash...!!!
Landi is not a brand.. :lmao:
StuckInTheMudd wrote:oh right! Is there any need for those rated recovery hooks/points then?
Definitely! Every single link / point / component must be rated. Ideally the single weakest point in the set-up should be in the recovery strap itself so that there is no chance of any metal bits being flung about in the event of a failure. The kinetic forces released during a failure can catapult a recovery hook / shackle right through a wind-shield and a seat inside the vehicle - imagine it hitting a bystander or vehicle occupant.
StuckInTheMudd wrote:You've got a point there. That got me thinking. There are shock absorbers for bumpers. Worthwhile? Or am I getting to complex now?
Yep, that's going too far - all well and good for the front but not for the rear if you're going to tow and certainly no good if it is placed so as to form part of the recovery components.
StuckInTheMudd
Town: Durbanville
Real Name: Greg
Changes wrote:Just fit a Bundu Gear bumper from Neil at 4x4 Direct and all issues and problems solved.... :-)
That would certainly be the easiest option, but whole point of this exercise to is not spend 7-10k :naah:
ChrisF wrote:Friend owns a panelbeater workshop.
Some more good advice :) should I perhaps use my existing tissue paper then? Just reinforce the mountings and put a square bar inside it...
Town: inniedorp
Vehicle: Toy
Post by ChrisF »
NOPE ! :)
The "bracket" must be the STRONG part - remember this is where your recovery points are.
It is the "face" of the bumper that has to be softer to do the bending, before the vehicle bends ...
StuckInTheMudd
Town: Durbanville
Real Name: Greg
ChrisF wrote:NOPE ! :)
That's what I meant, perhaps I didn't explain properly. :oops:
I meant weld strong brackets onto the chassis (with recovery points), then a square bar onto that and my existing soft bumper over that.
Dowe Koos
Real Name: Hennie
Post by Dowe Koos »
Rather a thick wall square tube than square bar.
StuckInTheMudd
Town: Durbanville
Real Name: Greg
could you send me a photo of what you're referring to please? I'm not familiar with these things. We may even be referring to the same thing.
Stef
Vehicle: '98 LTD
Real Name: Stefan
Club VHF Licence: X107
Post by Stef »
This is what I did in 2010 for the AAWDC fun day
viewtopic.php?f=35&t=12595&p=227555&hil ... ts#p227555
StuckInTheMudd wrote:could you send me a photo of what you're referring to please? I'm not familiar with these things. We may even be referring to the same thing.
Square bar is solid material - square tube is hollow tubing. :winkx:
StuckInTheMudd
Town: Durbanville
Real Name: Greg
Aaaah. Then I meant square tube. :oops:
Town: inniedorp
Vehicle: Toy
Post by ChrisF »
ooops. my bad.
