Laai stelsel kopkrap
Posted: Tue Mar 24, 2015 11:18 am
by bloubulon
Jy met die
ja jy, help my asseblief.
Ek het my 4x tjor met n National Luna dubbel battery laai stelsel, in my tjor het ek die altenator battery en n ekstra battery vir my yskas as ek gaan speel. Dit werk goed, geen probleem.
Nou vir die probleem;
Ek het n kamp sleepwa met ingeboude vrieskas , waterpomp, ligte en nog meer. 2x 105Ah batterye, n Ctek MXS 7.0 Laaier en n Ctek D250s DC/DC laaier en spaar nog vir die sonpaneel.
Van my voertuig het ek kabels wat ek kan konnekteer aan die sleepwa om te help met die laai van die sleepwa se batterye terwyl ek ry.
My vraag is nou,
Wat is die beste manier om die elektriese koppelings te doen vir die slaapwa met die laaiers wat ek het, en is dit moontlik om met my voertuig die batterye in die voertuig en die in die sleepwa gelyktydig te laai terwyl ek aan die beweeg is.
Dankie neh!
bloubulon.
Re: Laai stelsel kopkrap
Posted: Tue Mar 24, 2015 11:25 am
by WayneSchalk
Chris jou cabels vir die sleepwa moet direk van die hoof battery van bakkie af kom, onthou die fuse
Posted: Tue Mar 24, 2015 12:15 pm
by MOFASA
Posted: Tue Mar 24, 2015 2:08 pm
by ChrisF
First answer ONE question - what charging system will you be using in the trailer ?
Let's say it is a HCDP Mark 4 Power Panel - thus never more than 17 or 18A draw from the front.
10mm sqaure wired, as required by the Mk4 diagrams, is all you need to the back. No more than a 30A fuse AT THE FRONT battery.
brag harrison connectors near the tow hitch.
and jy is SORTED :)
Posted: Tue Mar 24, 2015 2:17 pm
by bloubulon
Thanks Julle, all is installed as u suggest. "but" ok lets take it from the Brad Harrison plug on the trailer side to the two chargers mounted in the trailer as mentioned above and the 2x batts. hoe word die koppelins en bedrading gedoen? Ive done it and it is working but not sure if ive done it correctly and done it in a way to get the optimal charge from the chargers. do i charge each battery seperate or can i charge both at the same time?
Posted: Tue Mar 24, 2015 2:27 pm
by bloubulon
Hi ChrisF,
Inside the trailer i am using a CTEK MXS 7.0 AC/DC charger that is connected to a CTEK D250S DC toDC Charger but without the Smartpass
Posted: Tue Mar 24, 2015 3:30 pm
by ChrisF
rewind .... how many batteries in the TRAILER ?
ek is maar VERSIGTIG vir battery banke (2 of 3 batterye in parallel) ....
Dan staan ek terug en los dit vir die slim manne :)
Die ander vraag - wat gebeur na die batterye ? Hoe koppel jy die yskas en legte ens ???
Posted: Tue Mar 24, 2015 5:39 pm
by bloubulon
In trailer 2x 105ah batteries in parallel with a bypass switch between the 2 batts. cables running from both the batts to the fridge/freezer where i fitted a Brad Harrison to connect to the fridge
Posted: Tue Mar 24, 2015 7:11 pm
by ChrisF
okay dan gaan ek liewer terug staan, en lees wat die manne sĂȘ wat al gespeel het met battery banke ....
Posted: Tue Mar 24, 2015 8:50 pm
by bloubulon
dankie inelkgeval vir die wat my probeer help het!
Posted: Wed Mar 25, 2015 9:31 pm
by Johan Kriel
Ek het nou 2 x105 batterye permanent paralel in my karavaan. Net vir ingeval die dag daar te veel wolke is. Daar is n hcdp mk 2 box, so moes nog n victron 75/15 controler koppel want die mk 2 kan max 120 wat solar vat. Ek gebruik 2 x 90 watt panele in serie op die controler. Ek gebruik nie sy 'load' konneksie nie, so net die regte setting gekies. Daai victron kan tot 75 volt vat, en laai of 12 of 24 volt , hy besluit self afhangend vand die batterye se volts, en as jy sy load konneksie gebruik kan hy die load afsit as die battery te ver ontlaai word.
Eintlik verkies ek nog altyd n ctek 250 dual, maar die mk box het darem n n paar ander funksies by, soos die volt en amp meter etc.
Ek het besluit om die battery in paralel permenent te koppel. Sal hulle maar net greeld dop hou, en sal hulle maar afsonderlik op n ctek 7.0 koppel as ek die karavaan nie gebruik nie. Jy het n beter kans as dit 2 van dieselfde maak en grootte battey is, dat hulle sal saam werk, anders laai die een of stadiger of vinnger as die ander een en met die tyd vrek een omdat dit nie genoeg gelaai word nie, of anderrs om
Die ander manier is om net een battery op n slag te gebruik, en te laai, maw die een is n backup soort van, maar dit raak werk.
PS n 12 V battery is elk geval 6 aparte selle, in beginsel 6 batterye, hulle moet net die selfde wees en dieselfde behandel word.
Posted: Thu Mar 26, 2015 10:37 am
by bloubulon
Dankie Johan,
Ek het nog een vraag, wat sal die beste wees, om die yskas te laat loop op net een battery op n slag en oor te skakel na die ander battery sodra die volts te laag raak of die yskas te laat loop op altwee batterye gelyktydig?
