I allways wanted to add a box at the back of my bakkie to keep all recovery gear and spare parts and gadgets and so on. Later I felt the need to also add a power point for a torch, pump or what ever the need may be as I run out of space in front at the normal lighter socket.
I had the box that I got from a friend when he sold his SFA. I had a vigo 2.7 d/c and then a SFA and then sold that one for my current one.Waited almost 3 years and finally did it. Glad I waited....
Sommer ran through a 3 core 2.5mm wire fron the front with a inline fuse. Secured the box to the loadbin with two bolts in the middle and four shock rubbers underneath each corner between the bin and the box to lift it a little and prevent rattles. I also fitted a light and switch I had laying arround to use at night when I want to take something out in the dark. I used connecter blocks so that I can add or take off things quickly. I only fitted a lighter plug for now but will add a hella plug later...I'm not a boffin at this type of thing so any comments on changes or improvements will be welcomed. Attached some picks.
Sent from my Samsung Galaxy Xcover2
Long due project filally done during december
- ôita
- Town: Piet Retief
- Vehicle: 1994 Toyota Hilux D/cab 4x4 SFA, 3RZ conversion,TrailGear Duel Transfercase with 4.7gear,Front & Rear Difflocks,2" Lift,OME & Mikem Suspention,Snorkel,L/R fuel tank, 32" M/T tyres, my son in the passenger seat
- Real Name: Kobus
- uploadfromtaptalk1420456650626.jpg (63.46 KiB) Viewed 2144 times
- uploadfromtaptalk1420456638255.jpg (56.88 KiB) Viewed 2144 times
- uploadfromtaptalk1420456625225.jpg (47 KiB) Viewed 2144 times
- uploadfromtaptalk1420456613964.jpg (45.94 KiB) Viewed 2144 times
- uploadfromtaptalk1420456580984.jpg (39.68 KiB) Viewed 2144 times
"Stronger than a New Zealand Kauri tree and, as we found out, virtually indestructible, the Hilux is an unapologetically manly car." - Top Gear Verdict
- Masekind
- Town: Lichtenburg
- Real Name: Drikus
Re: Long due project filally done during december
Baie nice
- Hangover
- Town: Deneysville
- Real Name: Stef
Jy moet dalk net daai draad fuse by die battery... n short brand n 1.5 f 2.5mmsq kabel soos niks af nie en dit is groot brand gevaar... daai lyk soos cabtyre en vir 1.5mmsq=15A en 2.5mmsq=25A fuse... Hou ook voltdrop in gedagte op maks stroom...
Hangover(A.K.A die speelding)
1976 FJ45 4x4
1UZ-FE 4.0vvti
2" OME Suspension lift
1.5" Shackle lift
35" Geo MT's
Custom Bullbar
Lockright Locked rear
York OBA
20" LED bar
Nighthawk 100W spots
Dakar
2013 3.0D-4D 4x4 Hilux Dakar
1976 FJ45 4x4
1UZ-FE 4.0vvti
1.5" Shackle lift
35" Geo MT's
Custom Bullbar
York OBA
20" LED bar
Dakar
- ôita
- Town: Piet Retief
- Real Name: Kobus
Ek het 'n fuse in by die battery (+) Ek het op die oomblik 'n 15A fuse in op die 2.5mm draad sal dit reg wees so of moet ek eerder 'n 25A insit? Dit is gewone 3 core 2.5mm "extention" draad.Met voltage drop beteken dit seker net dat ek nie dieselfde voltage agter sal hê oor daai afstand as wat ek voor sou hê nie. So 'n lig sal nie so helder brand nie???? Wat doen mens om so-iets te verhoed? Ek leer mar nog. Daars mos net een trick en dis electric.
- cprinsloo
- Vehicle: 1998 D/C 4x4
- Club VHF Licence: X52
'n 15A fuse sal vinniger pop as 'n 25A, geen probleem nie. Jy gaan seker nie sulke groot goeters hak nie. 12v x 25A = 300 watt, 12v x 15A = 180 watt.ôita wrote:Ek het 'n fuse in by die battery (+) Ek het op die oomblik 'n 15A fuse in op die 2.5mm draad sal dit reg wees so of moet ek eerder 'n 25A insit? Dit is gewone 3 core 2.5mm "extention" draad.
Die voltage drop sal groter word hoe meer stroom getrek word. Sal ook nie rerig 'n probleem wees nie. Dalk kan jy 'n LED gloeilamp in die lig sit, hulle trek baie minder stroom. Voltage drop is net belangrik as jy 'n tweede battery wil laai, kyk bv. hoe dun is die ligte agter se draadtjies.ôita wrote: Met voltage drop beteken dit seker net dat ek nie dieselfde voltage agter sal hê oor daai afstand as wat ek voor sou hê nie. So 'n lig sal nie so helder brand nie???? Wat doen mens om so-iets te verhoed? Ek leer mar nog. Daars mos net een trick en dis electric.
1998 Hilux D/C Lexus VVTi
- ôita
- Town: Piet Retief
- Real Name: Kobus
Baie dankie daar leer ek nog iets by....Daai geel liggie gaan net vinnig gebruik word (2-3min) as ek iets binne-in soek.Gelukkig vir geen ander doel nie. Sal die tipe draad wat ek gebruik het reg wees?Wat is die max watt's wat ek kan trek of daardie draad?
- cprinsloo
Soos Stef gesê het, 25 A vir 2.5 mm^2, dit is 300 Watt.ôita wrote:Baie dankie daar leer ek nog iets by....Daai geel liggie gaan net vinnig gebruik word (2-3min) as ek iets binne-in soek.Gelukkig vir geen ander doel nie. Sal die tipe draad wat ek gebruik het reg wees?Wat is die max watt's wat ek kan trek of daardie draad?
Hello Kobus netjies projek.
as ek dalk n bietje raad kan byvoeg - die probleem met die "female plugs" is altyd daai kaal krag punte.
Kyk bietjie na die boksies wat ek gebruik het om daai punte veilig te hou - viewtopic.php?f=41&t=37810" onclick="window.open(this.href);return false;
sien post 6 vir n foto van die boksie.
- ôita
- Town: Piet Retief
- Real Name: Kobus
Dankie. Ek het dit raakgesien. Waar kan mens sulke boksies kry? Hier inie platteland sien mens nie altyd als raak wat beskikbaar is nie. Gewoonlik sien mens iets raak en weet dan eers dis waarna jy soek. Wens mens kom vrylik in n plek se rakke agter rondloop. Mens sal vinniger iets kry wat sal werk vir n projek....
