Service - at home OR at dealer ?
Short history
2010 I purchased my Hilux at Barloworld Toyota Tygervalley
services has mostly been a PAIN, three of the previous 5 services it had to go back to the workshop due to half work
It is now due for its final service under the 5 year service plan. They have confirmed the service items as:
- oil change
- oil filter
- air filter
- polin filter
QUESTION - is it worth the trouble to take my baby to these incompetents one final time ?
Or do I just save myself a lot of frustrations and do this at home - WHILE I then take the time to grease the nipples on the drive shaft, and CHECK each and every item PROPERLY ??
bear in mind we are hoping to do some trips next year. So I will have to do these checks in any case
- oil change
- oil filter
- air filter
- polin filter
- Umpalumpa
- Town: Jacobsbay
- Vehicle: Hilux 3.0 D-4D DC, 4x4=16
- Real Name: Jacques
- Club VHF Licence: HC305
Re: Service - at home OR at dealer ?
I will just bite the bullet, mark all your parts that need to be replaced, and make sure they are replaced when you take it in.
You paid for it, might as well use it.
At least you will get a free car wash as well
Just a guy with a passion for 4x4.....
NEE !!
laas wat daai moere my bakkie gewas het, het hulle die matte se clips afgebreek !
My gekos die delaer principle uit sy kantoor sleep voor hulle dit vervang het !!!
Jacques I walked in there this morning to make the appointment ... 5 minutes later my blood pressure was sky high.
nee daai plek maak my net kwaad.
- Umpalumpa
- Town: Jacobsbay
In that case it seems settled.
A service you do yourself at home is WAYYYYYYYYYYYY cheaper than a heart attack and/or rehab for strokes.
Gaan vir goud!!!
Gaan vir goud!!!
HOPPY - what oil do you recommend for a 2,5 D-4D ?
The invoice just say 10W30, it does not give any brand name
I prefer to do it myself, then I know what has been done and what not.
For big things I will take it to them, sometimes more because I do not feel lus for the hassle.
But a service is really so simple I cannot see why you need to be without a vehicle for a day.
What bothers me also is....
Nowadays all garages have this big oil container on wheels which they put under the vehicle to drain the oil and all vehicles' oil go in one big container, it is much easier. But the thing is, there is no way they can see how much oil they drain, ie they have no clue whether your vehicle is using oil or not. Also in the sever case of something really bad being wrong inside the engine, if you drain the oil and let it stand for 10 minutes you can see metal on the surface. Something which is also not possible with their way of doing.
And then of course, you have absolutely no clue what oil they put in your bakkie. They can tell you they use super dropper XXL whatever, but do they really use it or do they use the cheapest which can result in the highest profit?
Most their filters are manufactured by GUD, you can buy your own. Oil you can buy the best you willing to spend.
Chances are much bigger that if you see something loose or worn out, you will immediately fix it or make a plan to fix it, many workshops will just leave it because the car was not booked in for that problem.
To me it is not about the cost saving, but about knowing what is going on with my vehicle.
Pieter the bakkie had about 40 000 km when I crawled under it to check it myself before a trip.
they had not once touched the grease nipples !
I had to go buy a grease gun, took me a while to figure out where all the nipples were - and only a few minutes to do it
hulle is net plein slapgat.
- Toppie4x4
- Town: Centurion
- Vehicle: Hilux 4.0 V6 DC 4x4
- Real Name: Andre
Is daar nie n ander dealer nie, ek kan glad nie kla oor ons diens in Centurion Gauteng nie, het ook vir twee jaar goeie diens gekry in Ballito by Toyota?
- DawidT
- Town: Witbank
- Vehicle: Toyota Hilux, 2.5D4D, DC 4X4
- Real Name: Dawid
Doen dit self, baie vining om filters en olie te ruil - dit het my omtrent 40 minute gevat om alles te doen die naweek en teen n koste van minder as R600. ek het egter nie die pollen filter vervang nie...... waar sit die ding?
Stem saam met jou, het selfs in die tyd my agter diff olie level ook gekyk en sommer onder di Hilux gele en kyk wat aangaan terwyl ek gewag het vir die laaste paar olie druppels om klaar te drup.
Met die vorige diens het ek die timing belt en waterpomp ook self vervang - dankie "You tube"
Dawid as jy die cubby-hole uithaal sien jy die polin filter se housing
ek het in 2010 kon kies tussen twee deals - Toyota 100m weg van my kantoor, of een n paar kilometer verder. Ek het hier reg langs ons gekoop vir die gemak daarvan om nie te sukkel wanneer die voertuig gediens moet word nie. (en die deal was nogal n paar honder rand duurder)Toppie4x4 wrote:Is daar nie n ander dealer nie, ek kan glad nie kla oor ons diens in Centurion Gauteng nie, het ook vir twee jaar goeie diens gekry in Ballito by Toyota?
net so jammer die lot se werkswinkel is so pateties.
Die volgende opsie is die Kuilsrivier tak, seker 15km verder - MAAR in spitsverkeer heelwat meer as n uur heen en terug !!
PS - beste diens ooit was by Toyota Upington. Net jammer dit is so "bietjie" ver van my af
- Omo
- Vehicle: Ford Ranger super cab 3.0 xlt 4x4
- Club VHF Licence: HC236
Ons hier by Toyota Kuilsrivier kan jou bakkie kom haal en weer deliver as ons klaar is met die diens. (en ons grease die nipples)
There a two kind of people. Those who pushes a door when it says pull and they who pull a door when it says push.
- Real Name: Rian
Ek het mos so ander probleempie, twee dae na my diens op 70000km gaan ek mos na die manne toe. Vra toe, het julle my airfilter vervang? "nee Mnr dis eers geskeduleer vir die 80000km". Ek sê toe ja, maar blaas julle darem die ding bietjie want ek ry baie gruispad. "Ja Mnr" Nou maak oop! Die man haal daai airfilter uit en die stof/grond en grassade val sommer so af! En dit?! "Nee Mnr, Ek het nie op die voertuig gewerk nie" Wel, ek het die bonnet toe gedonner en na Autozone gery en vir my 'n filter gaan koop!
Dewald dis waar hy is :ChrisF wrote:Dawid as jy die cubby-hole uithaal sien jy die polin filter se housing
Rian ons doen n drie weke Namibie trip. Kom by die huis en drie dae later word die Hilux gediens.Rianc wrote:Ek het mos so ander probleempie, twee dae na my diens op 70000km gaan ek mos na die manne toe. Vra toe, het julle my airfilter vervang? "nee Mnr dis eers geskeduleer vir die 80000km". Ek sê toe ja, maar blaas julle darem die ding bietjie want ek ry baie gruispad. "Ja Mnr" Nou maak oop! Die man haal daai airfilter uit en die stof/grond en grassade val sommer so af! En dit?! "Nee Mnr, Ek het nie op die voertuig gewerk nie" Wel, ek het die bonnet toe gedonner en na Autozone gery en vir my 'n filter gaan koop!
na die diens kyk ek na die "invoice" .... geen air filter nie .... okay, dit is NIE op die skedule vir 20k nie, maar kom ons kyk maar of hy uitgeblaas is :
tussen my bakkie en my kar het 5 van die laaste 8 dienste in n onaangename storie ontaard. Elke keer maar die Dealer Principle beloftes, elke keer maak die "Service Manager" beloftes .... maar steeds word die voertuig oorhandig sonder dat die "Service Advisor" eers om die kar stap
wag, los maar, my moer meter loop nou weer onnodig hoog die Tygervallei tak.
Baie dankie vir die offer. Ek het vir jou n PM gestuur.Omo wrote:Ons hier by Toyota Kuilsrivier kan jou bakkie kom haal en weer deliver as ons klaar is met die diens. (en ons grease die nipples)
Ja, al is dit net om die stamp in die boek te kry. Doen dan maar weer jou eie diens.
- Town: Centurion Gauteng
- Vehicle: Mazda Rustler 16v
- Real Name: Jan
As die tegnikuste by ons sulke stront aanjaag is hulle kniediep in die bollie . het in die jaar al van drie sulke chancers ontslae geraak
DANKIE :)ChrisF wrote:Baie dankie vir die offer. Ek het vir jou n PM gestuur.Omo wrote:Ons hier by Toyota Kuilsrivier kan jou bakkie kom haal en weer deliver as ons klaar is met die diens. (en ons grease die nipples)
Update - Die Kuilsrivier tak gaan Maandag my wa diens. Omdat dit n "minor service" is gaan ek sommer daar wag.
- 4x4BEES
- Vehicle: Hilux 4.0V6
- Real Name: Kevin
Hoop dis wat jy nodig het om weer bietjie gelukkig te wees
- Bugzy
- Town: Rustenburg
- Vehicle: 2015 Hilux S/C 4X4 Dakar1996 2.8D s/c 4x4 Hilux with 3CT Toyota motor
- Real Name: Buks
- Club VHF Licence: X56
R480.00(+VAT) om die remote se batterytjie te vervang......ek dink nie dit is 'n grap nie.
- Donkey
- Club VHF Licence: X122
Toyota wanted R3500 for a normal service on our Yaris
Geniune spares cost me R720 + R0.00 labour doing it myself. This was the 75 000km service. Having done the service myself, I doubt if the dealer did the 60 000km one, went front to back thouroughly and I now know the condition of the Yaris and can be at ease whenever CupCake is out.
Have to agree with Pieter, besides saving on costs, doing it yourself gives a true sense of security/reliability. Now she pulls like a new car!!! Whereas before even a slight incline required changing down.
Tumelo Maketekete
- Real Name: Zeek
My experience at B/world Tygervalley has only been good so far (3 or 4 visits). I get along well with the service advisor and he looks after me. Sad to hear I'm in the minority.
BAIE BAIE baie dankie Louis !!Omo wrote:Ons hier by Toyota Kuilsrivier kan jou bakkie kom haal en weer deliver as ons klaar is met die diens. (en ons grease die nipples)
had a nice koffee while the service was done.
and over comes the service advisor and the mechanic .... hier kom n ding ...
at the Hilux he points out the brake balance valve - due to the aftermarket suspension it is standing tall WITH a load in the back, thus the balance valve is NOT distributing extra braking to the back as it should .... yada yada ... Now bear in mind that the suspension was done with 2 000km on the clock - so it has been in and out of that other dealership how many times and not once did they bother to point this out !! (okay I do feel dof for not having picked this up myself ..)
Kuilsrivier Toyota MAG MAAR !
- Town: Bellville
- Vehicle: V8 Disco 1
- Real Name: Dirk
Het self noudie dag goeie diens daar by Louise by kuilsrivier gekry
En ook n heel goeie pryse op my petrol pomp gekry
