screeching belt
- hilex08
- Town: Springs
- Vehicle: Hilex V8, Ford Ranger 2500 td, C55 AMG
- Real Name: Hennie
screeching belt
Help....
The old LS 400 beats me.......
why does my fan belt screech when i start? It dies after a little revving and keeps quiet until i re-start again
the belt is tensioned to what I think it should be, and i sprayed a little bit of "combat"on the belt while it idles, but to no avail
any ideas/recommendation out there?
Re: screeching belt
I have the same problem with my Kaspaas.
Re: screeching belt
How old is the belt and how sure are you that the tension is correct (factory spec)?
- Scooter
- Town: JHB
- Real Name: Scott
Re: screeching belt
Could be the type (make) of belt you are using.
I would change the belt and makes sure all the pulleys are running straight. :|
- Scorpion
- Town: Emmarentia
- Real Name: Johann
Re: screeching belt
"Stop dicing in the early mornings! The car needs to warm up properly first, otherwise the belt will stretch..."
That was my Grandfathers advice when I had the same problem with my first Golf!
1978 Land Cruiser HJ45
Re: screeching belt
Belt is brand new... and set to spec...CasKru wrote:How old is the belt and how sure are you that the tension is correct (factory spec)?
Re: screeching belt
My 22R does not have 3 belts.... oh wait, I don't have a 22R...
Re: screeching belt
Kaspaas wrote:My 22R does not have 3 belts.... oh wait, I don't have a 22R...
Mine has a black belt!
- hilex08
- Town: Springs
- Real Name: Hennie
Re: screeching belt
uh uh....the problem started when the fuses kept popping, the fuses and wires are now safely tucked away and fixed, but the belt still goes..........SCREEEEEEEEEEEEEECH..........
Re: screeching belt
Treat your van's belts with some good quality Silicon spray. Professor Dadz Toy can give you the run down on what to buy, I normaly just stop of at a friend who has a workshop and aske him to spray my belts.
- hilex08
- Town: Springs
- Real Name: Hennie
Re: screeching belt
silicon spray?, never thought of that !!!
thanks Bennie !
thanks Bennie !
- Town: Rustenburg
- Vehicle: 2002 KZTE 4x4 Hilux
- Real Name: Brink
- Club VHF Licence: Goba
Re: screeching belt
Help ! What would the facoty settings be for 2002 KZ fan and other engin belts
Re: screeching belt
I've always set belt tensions by feel . Too tight and you will run bearings on the Alt / water pump / steering pump / compressor etc. Too loose and te belt will screech. As a guide line, tension to the point that you still have 5mm 'give' across the longest open section of the belt if held between forefinger and thumb (not with brute force). Never had a problem in over 35yrs doing it that way.
- hilex08
- Town: Springs
- Real Name: Hennie
Re: screeching belt
I eventually changed the belt for a new one.
Problem was, that my lexus has no power steering nor aircon, so the belt is a "measured to fit belt", and only runs thru/over the crank, tensioner, waterpump, and alternator.
Was a real mission to fit the new belt, and problem solved.
Tried silicon spray, belt dressing, sunlight soap, but nothing helped. The belt simply stretched so far that the tensioner was on the max.
Re: screeching belt
Glad you came right! Just as a matter of interest .... I've tried various products over the years, and of the aerosol spray types found Spanjaard Belt Dressing to be one of the better ones, but it doesn't beat good old beeswax if you can get it .... that belt runs so quiet you can hardly hear it! Generally a non petroleum based wax would be a better option than the aerosols IMO.
- Town: White River
- Vehicle: Hilux Raider v6 4.0 ; SYNCRO 2l
- Real Name: Jan
Re: screeching belt
Ek het baie jare terug die boereraat gekry om die belt met water skoon te spuit, te laat droog word en dan met remvloeistof te vryf - neem 'n bondeltjie toiletpaier, doop dit vinnig in die remvloeistofhouertjie en vee die belt daarmee. Dit werk, en kon nog nooit sien dat dit skade doen nie. Al die ander goete sal ook seker werk, maar 'n mens het nie noodwendig by jou as die geskrou begin nie. Remvloeistof is altyd met jou.
- Town: Springs
- Real Name: Heinrich
- Club VHF Licence: X81
Re: screeching belt
Do not use silicon spray on belts. You are reducing its lifespan.
Use a good belt dressing spray, like Wurth or Spanjaard. I use Wurth.
If it stretches so soon you might be running to high tension. Have you tried a ribbed belt like the Goodyear Gator?
Know what you don't know.
- Polarbear2008
- Real Name: Theunis
- Club VHF Licence: X49
Re: screeching belt
AFAIK regarding belt tension - when it is set correctly, you should be able to grab hold of the belt and give it a quarter turn only, then it is set correctly. If you can't turn in a quarter of the way, it is too tight! As easy as that.
Monroe Gas Magnum shocks
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
