Victron
Posted: Tue Nov 18, 2014 6:13 pm
by louis fourie
Het enige iemand al dié solar regulator gebruik?
http://www.sustainable.co.za/victron-bl ... oller.html" onclick="window.open(this.href);return false;
Ek kan nie besluit of ek die HCdP roete moet gaan of bg. regulator nie. Wat ek hou van die Victron (as ek dit reg verstaan) is dat jy 2 aparte batterye afsonderlik kan laai. HCdP het weer ander voordele. My grootste doel voor oë is om die 2 batterye in my Companion saam te kan gebruik sonder dat hulle in parallel gekoppel is.
Sent from my IdeaTab S6000-H using Tapatalk
Re: Victron
Posted: Tue Nov 18, 2014 6:58 pm
by ROOFER
Hi Louis how odd is this as I have just today looked at the Cyrix ct 12/24v battery combiner and wanting to get some feed back on the system .
My question is how does it compare with what is out there all ready & who's using it
Any feed back will be greatly appreciated .
Waar is die Slim manne :!: :!: :!:
Re: Victron
Posted: Tue Nov 18, 2014 7:02 pm
by ROOFER
Sorry the web site is www. victronenergy.com
Re: Victron
Posted: Tue Nov 18, 2014 8:05 pm
by JamesC
Victron is the best. Dutch company that started life producing power untis for ship at sea.
Long long history of supplying into Africa. Not as fancy as the American and Chinese counterparts...more expensive and WAY MORE ROBUST.
I only use Victron in my installations. You cannot go wrong.
Re: Victron
Posted: Wed Nov 19, 2014 9:09 am
by KOBUSL
JamesC wrote:Victron is the best. Dutch company that started life producing power untis for ship at sea.
Van die heel beste, saam met Outback. Sorg dat jou " controller " MPPT is.
Re: Victron
Posted: Wed Nov 19, 2014 5:30 pm
by JamesC
Ek gebruik nou Victron se MPPT ook instede van Outback.
Laat weet as julle pryse soek.
Re: Victron
Posted: Wed Nov 19, 2014 5:31 pm
by louis fourie
JamesC wrote:Ek gebruik nou Victron se MPPT ook instede van Outback.
Hallo James
Ons soek pryse:D
Re: Victron
Posted: Wed Nov 19, 2014 8:24 pm
by JamesC
Vir wat?
Wat is die applikasie?
Hoe groot moet inverter wees? 24V? 48v? 50A? 5kva? 3kva?
Mppt - hoeveel amps?
Watse batterye gebruik jy? Moet tog net nie 12V gebruik nie
Re: Victron
Posted: Thu Nov 20, 2014 12:15 am
by ROOFER
Wat is fout met n' 12v James hoekom nie te klein /swak
Re: Victron
Posted: Thu Nov 20, 2014 6:08 am
by JamesC
Hang af van die applikasie. Vir huishouding is 12V nie goed nie omdat sy tegniese spesifikasie nie goed vergelyk met 2V nie. 2V laai en ontlaai op beter kurwes. Dus, hoe laer die spaning van die sel, hoe meer effektief. Aan die anderkant, hoe groter die spanning van die inverter, meer effektief.
