D4D oil??
- sir shrek
- Vehicle: '09 Hilux D/C 4.0 V6 AKA 'BULLET' Hilux D/C 7M-GE aka SIR SHREK(SOLD) Jetta MK5 2.0TFSI
- Real Name: Claude
D4D oil??
Hi Guys
The time has come to do a oil change on my 3.0 D4D. It is a 2008 model with 170 000km on.
What oil do you guys recon I should use. Personally I prefer Shell. On my 3.0 5L i used to use Rimula but with these new generation turbo diesels I have no clue.
One of my suppliers said that I should use the new series Rimula and the guy at the Shell garage said HX5.
I would appreciate your input.
3" suspension lift 31" bfg muds dual fuel tanks custom bushbar 7M-GE
Rear Diff Lock Custom made snorkel
UGLY LIKE SHREK,STRONG LIKE RUSSIA
- Real Name: Marnus
Re: D4D oil??
If you look at the owners manual it is surprising that the oil specification is not that high at all. Having said that I really believe in using good oil. In mine I have used Caltex Delo 400 from its 100 000 km service right up to now at 245 000 kms.
I'm not too familiar with the current range of Shell oils but just look for the one made for turbo diesel engines and it should be fine.
- Vehicle: 2008 Toyota Hilux 3.0D4d 4x4
- Real Name: Dewald
Re: D4D oil??
I have the same model and mileage, and like Mars, I also use Caltex Delo 400.
- JohanW
- Town: Strand
Re: D4D oil??
Op my KZ, wat sonder die "snot seperator" (dit haal blykbaar bietjie carbon uit die olie wat die D4D het) het ek al shell hx3, hx5, hx7 en fuchs titan 20w50 geloop. Caltex delo gold 400 is by midas vir R189 vir 5L. Dit is sover die een wat vir my die beste verrigting en skoonste olie los by diens tyd. Die KZ verbruik ook die minste olie daarop.
- Real Name: Marnus
Re: D4D oil??
Ken dit nie regtig nie maar die manne (Naskar) sê dit is goed. Ek het hulle vol sintetiese olie nou gekoop om in my Porsche Spyder kit kar te probeer om te kyk hoe maak dit.
Ek sien op die Internet dat hulle deel is van GUD Holdings.
- dalkill
- Town: Cape TOwn
- Vehicle: 2.4 GD6 SR D/C 4x4
- Real Name: Shaakir
Re: D4D oil??
hilux due for it's 220K service... been reading up on some oils to use...
according to some services at dealers i see they use 10W30. But alot here uses Delo 400 which is 15W40 ????
why would Toyota use thicker oil?
TOYOTA IS MY LEWE
TOYOTA IS MY LEWE
- JohanW
- Town: Strand
Re: D4D oil??
Thinner!dalkill wrote:hilux due for it's 220K service... been reading up on some oils to use...
why would Toyota usethicker oil?
From manual.
If the quality is visibly poor, replace the oil.
Oil grade:
API CF--4 or CF (You may also use API CE or CD)
If you use SAE 10W--30 or higher viscosity oil in extremely low
temperatures, the engine may become difficult to start, so SAE
5W--30 engine oil is recommended.
- oil_visc.png (19.17 KiB) Viewed 7776 times
- Real Name: Marnus
Re: D4D oil??
You can use the Delo 400 with confidence. My Lux has done 179 000 ks on Delo 400 now. Still not using a drop of oil.dalkill wrote:hilux due for it's 220K service... been reading up on some oils to use...
- dalkill
- Town: Cape TOwn
Re: D4D oil??
JohanW wrote:Thinner!
i always thought the lower those numbers are the thicker the oil.
thinking that diesel engines needed a thicker oil (higher viscosity ???)
TOYOTA IS MY LEWE
TOYOTA IS MY LEWE
