Has anyone tried after market air filters on their D4D's?
Something like a K&N or a BMC? Are they available? Are they worth it?
I See value in them, in that they are washable and reusable and generally there is a performance advantage
Aftermarket air filters
- Real Name: Marnus
Re: Aftermarket air filters
I would not consider them if you are going to drive in dusty conditions. I also understand that the amount of research that goes into making sure the original air cleaners are efficient means that using an after market filter will not necessarily give you a noticeable difference in performance and some say it may actually be worse.
- Town: Kyalami
- Real Name: Mike
The thing is that you oil those filters and they catch a lot more dust, On my bike they are a god send and they see a lot of dust.
- Real Name: Marnus
True but the standard air cleaner has a cyclonic action which causes the largest dust particles to be flung out exposing the filter element to less dust and it has a much larger surface area therefore it takes longer to clog up. - granted you can wash and re-oil the others but you will need to do that more often.
- Town: Kyalami
- Real Name: Mike
Cool point taken
- FIRSTGEER
- Town: King WilliamsTown
- Real Name: Tony Geer
- Club VHF Licence: HC 109
K+N type filters are a NO GO for offroad vehicles. They are okay for street drag cars driven in a clean enviroment.The standard filters fitted by the manufacturer are far more superior and are designed for use in all types of conditions.
- hansman
- Town: pretoria
- Vehicle: hilux sfa
- Real Name: hans
Hi
Die kleinste partikel wat n KN filter keer is n mossie hou by die Donaldson tipe dit is die moeite werd.
niks so goed vir enige engine as skoon lug nie!!!!!!(maar genoeg daarvan)
Hansman&Vaaltyn
Hansman&Vaaltyn
- Town: Helderkruin
- Vehicle: Hilux D-4D
I use a K&N filter in my D4D and it works fantastic. I you're considering it, you will love it.
Just until your motor stops performing and you discover that there's very little compression on all cylinders. Then you'll have to re-bore, replace pistons and rings - you will have to do bearings at the same time, then there's the costs of skimming, gaskets and labour. The K&N will turn out to be the most expensive filter you can buy.Dippies wrote:I use a K&N filter in my D4D and it works fantastic. I you're considering it, you will love it.
If you're going to use the Lux in dusty conditions, stay with the Donaldson, there's no better air filter - clean the element regularly and replace if it becomes too dirty / choked.
Think about that for every litre of fuel you burn through the motor, you pass about 30,000 litres of air trough it.
I have seen what dust can do to a cylinder bore and rings - it ain't pretty.
- Wave
- Town: Edenvale
- Vehicle: Tuna 3.0 D4D 4x4
- Real Name: Geoff
I would go for it, the K&N is my brand of choice, had many over the years and been very happy
If you are going in to dusty conditions just slap in the stock filter :)
'09 Toyota Fortuner 3.0 D4D 4x4 (M)
'14 VW Polo 1.2 TSI H/L (Swambo's)
'10 Conqueror Comfort
