Help with seals please
SYRON CONVERSIONS
Town: Tamboekieland
Vehicle: SFA HILUX
Real Name: SIMON
Post by SYRON CONVERSIONS »
I'm looking for special (square rubber profile) rings for my brakes on my FDI SAMBRON machine, it is know as a T 2567 Serial number 220002690.
I hope that someone will be able to assist me here, we have tried Bearing International as well as Bearing Man and a few other places down this way to obtain these rubber seals for the pistons on the FDI Sambron front and rear brakes, but we cannot get them.
The small OD is 252.5mm
The large OD is 307mm
The square profiles are 4mm wide and 3.5mm thick, I am needing for the front and the rear diffs on this machine, in other words 6 of the one size and 6 of the other larger size.
Thanking You
Kind Regards
Simon cell. 083 703 6430
(45.62 KiB) Downloaded 139 times
simoan
Re: Help with seals please
Post by Mars »
Praat met Attie by Pretoria Seal Centre. 012 379 6170. Dalk kan hy jou help om te kry.
Ek het ook op 'n stadium na vierkantige profiel O-rings gesoek en toe sê hy mens kan rondes ook gebruik.
mcw
Town: krugersdorp
Vehicle: Prado 90 V6 3.4 Auto
Real Name: Martin
Club VHF Licence: X100
Post by mcw »
Hi I have dealt with for 3 years now , but the used to make any seals ,shapes, sizes ,materials for us
POLYFLEX SEALS
Address
Physical Address:
132 Main Reef Rd,
Benrose,
Johannesburg,
2094
Postal Address:
PO Box 27087,
Benrose,
Johannesburg,
2011
Contact Details
Phone:
011 614 1014
Fax:
011 614 9345
Hope you get helped.
Martin
