heaven help me...please
- Town: Potchefstroom
- Vehicle: SRX 2.5 4x4 D/C
- Real Name: James
So my uncle borrowed the V6 Hilux till sunday to go the waterberg...and left me his nissan 24v 2. whatever ailing nissan!!!!!!!!!!!
All mechanics have checked and replaced fuel pump, filter, MAF cleaned...
But this this stutters and burps and farts like you have never heard. Any ideas to keep me busy till sunday?
James Cameron
0834431879
0834431879
- Dingo
- Vehicle: 95 4x4 DC Hilux, 7MG engine, EFS suspension, Home made custom off-road canopy.
- Real Name: Scott
Re: heaven help me...please
A Nissan
I assume it's petrol. How is it aspirated - carb or EFI?
- Real Name: James
It has a carb but then fuel injection on the block... dunno how that works really.
Took the petrol cap off today and seems better...as if breather pipe is blocked perhaps.
Also has a fuel return valve on the injection rail that might be faulty?
Ran diagnostics on it today - no electronic faults.
My kids are embarrassed to drive with me in da nissaaan
James Cameron
0834431879
0834431879
- george
- Town: Velddrif
- Vehicle: Triton 3.5l V6
- Club VHF Licence: HC107
You have good kids. treat them well
That doesn't make sense, it's either or. The fact that you speak of a pressure regulatory valve on the injection rail means it's EFI. You may be mistaking an old type bulky airflow meter and throttle body as a carb. If it seems to run better with the fuel cap removed, it makes me wonder .... if the fuel cap breather is blocked the tank will be a little pressurised, not vacuum as one might be inclined to think due to fuel being used. Such pressure may slightly increase the pressure from the pump but it shouldn't be that significant - furthermore the pressure regulator on the fuel rail would compensate. If it's a fuel problem, it's either too rich or too lean - do you get the smell of unburned fuel when it's running? If the pressure is right, then it could be faulty injectors, but with petrol motors these seldom give hassles. Have you checked the ignition .... plugs / leads etc?JamesC wrote:It has a carb but then fuel injection on the block... dunno how that works really.
- Oupa Stig
- Town: Johannesbug
- Real Name: Mickey
James, I had a Nissan 2.4 hardbody with 460k kilos on the clock by the time I sold it (great motor, thirsty though)
Also had the stutter/farting business going at some stage, had the carb overhauled, still same trouble. Had me pulling my hair out, and running from one mechanic to the next trying to figure it out, no one could help. Then one day the farting started up again, and I saw a signboard for a mechanic, so I pulled in. The guy came out, listened to the idling, told me to switch off, fiddled for about a minute, told me to start, everything was perfect. Turns out the hinge on the float in the float chamber was sticking. A quick bend, no more hassles.
And if that fails, you can borrow some matches from me...
Rightfully so!JamesC wrote: My kids are embarrassed to drive with me in da nissaaan
- Real Name: James
OK. EFI then. If it is not a Toy V6 I am looking at, I get a bit lost...
Mickey, sounds like you are onto something. Cleaned the "carb" yesterday thoroughly.
Andy, no smell of unburnt fuel.
James Cameron
0834431879
0834431879
- Bugzy
- Town: Rustenburg
- Vehicle: 2015 Hilux S/C 4X4 Dakar1996 2.8D s/c 4x4 Hilux with 3CT Toyota motor
- Real Name: Buks
- Club VHF Licence: X56
JamesC wrote:My kids are embarrassed to drive with me in da nissaaan
You brought your kids up properly!!
- Vehicle: 1995 SFA
Fuel filter and fuel pump. A friend once struggled with his 2.4 that had a bad case of hiccups....
- Real Name: James
Changed the fuel filter and pump...still the same...today it also backfired...I thought I was on the East Rand...
James Cameron
0834431879
0834431879
- Hoppy
- Vehicle: Hilux SFA & IFS
- Real Name: Allan 0721291160
Contaminated fuel?
- Real Name: James
I doubt it...it runs fine for long periods and then suddenly, without warning, there will be a loss of power, stuttering, splurting and farting along and then just as suddenly gone again...
Steps taken:
1. Changed fuel pump and fuel filter
2. cleaned maf
3. cleaned the "carb" of the efi
4. tested breather pipe and drove without petrol cap - no change
5. had comp diagnostics on it - no faults. (shows crank sensor on zero but mechanic thought that is because it has a distributor cap)
to me it feels like a fuel supply issue
can the fuel relay on the efi rail be faulty?
Steps taken:
2. cleaned maf
James Cameron
0834431879
0834431879
With it being intermittent as you now describe, it sounds more like an electrical issue - like a poor connection somewhere.
Intermittent faults are a bugger to pin point.
you own a TOYOTA
you now drive a dustbin ....
sorry, what did I miss ??? WHY do this to yourself ??
what to do till Sunday - bang head against wall ....
- ForYota
- Town: Gauteng
- Real Name: Hennie
Skoonpa se Cresida het so gemaak, dit was sludge in die petrol tenk.. elke nou en dan bietjie bietjie van die gemors deur die carb getrek..
Hoop jy kom reg
Hoop jy kom reg
