SFA Brake Calipers
IndianaJones7746
Town: Citrusdal
Vehicle: 84 SFA Hilux
Real Name: Ben
SFA Brake Calipers
Post by IndianaJones7746 »
Hi Guys
Does anyone know which parts store, carries replacement SFA front brake calipers?
Or the Toyota part number for the Caliper Service Kit, and what parts is all included in this kit?
Does Powerbrake sell replacement calipers, or only calipers for the upgraded vented discs?
Or does anyone perhaps have a used set in good condition for me to buy?
Regards
Warrior
Town: Brackenfell Cape Town
Vehicle: 08 Vigo 4x4 d/c 4.0L auto
Real Name: Eben
Club VHF Licence: X138
Re: SFA Brake Calipers
Post by Warrior »
Try your nearest Goldwagen branch - they started with Toyota spares now but the knowledge and part numbers are "n bietjie deurmekaar" at the moment. Teething problems.
mcw
Town: krugersdorp
Vehicle: Prado 90 V6 3.4 Auto
Real Name: Martin
Club VHF Licence: X100
Post by mcw »
Midas also carry this part bought mine 1 month ago for 600.00 from them fitted perfectly (MSD4277)
i have a 96 Raider 2.4 DC
Martin
IndianaJones7746
Town: Citrusdal
Real Name: Ben
Die Midas wat ek probeer het, se daar is nie vooorraad nie.
mcw
Town: krugersdorp
Real Name: Martin
Post by mcw »
Gemini auto spares in johannesburg het ook gehad
dis net om dit daar onder te kry
Martin
The Legend
Real Name: Dawie
Club VHF Licence: X93-
Post by The Legend »
The Toyota kit partnr is 04479 30031 (cylinder kit disc) Includes caliper seels dust covers and dust cover clips
Grootseun
Vehicle: 1988 SFA DC Lexus
Real Name: Driko
Post by Grootseun »
Bought a set for R200 from my part guys only to discover the piston were pitted so badly i cant repair them so i have a seal kit and caliper casing in stock minus the pistons , i can check the part number tomorrow when im at the shop for you
IndianaJones7746
Town: Citrusdal
Real Name: Ben
Thanks guys, can one buy the loose pistons too?
To repair the set I have, I would need pistons and seal kits.
Not as far as I know .... just seal kits, anti-squeal shims and anti-rattle springs. Never come a cross piston replacement spares. A pity, because even if the sleeve in the body is pitted, it makes very little difference as long as the seal seat is good. A pitted piston on the other hand compromises the whole assembly.
Hoppy
Vehicle: Hilux SFA & IFS
Real Name: Allan 0721291160
Post by Hoppy »
Ek verkoop recon calipers vir R500.oo elk op exchange
IndianaJones7746
Town: Citrusdal
Real Name: Ben
Hoppy wrote:Ek verkoop recon calipers vir R500.oo elk op exchange
Verkoop jy nog recon calipers op exchange, Allen?
Bosfebok
Town: Roodekrans
Vehicle: 1995 Hilux Raider 2.2
Real Name: Otto
Club VHF Licence: X248
Post by Bosfebok »
Ouens, doen julleself 'n guns voordat jy jou calipers op 'n 2.2 SFA vervang.. Kry FJ75 disc, KZTE 4 pot calipers en die KZTE master cylinder... als pas mooi en jou bakkie briek soos 'n bom!
Otto X248
20.5" LED BAR
Nudge-M front bumper
80l Long Range Fuel Tank
90l Water Tank
Slide Drawer System
Safari Snorkel
Diff breathers
Reinart21
Town: Secunda
Real Name: Reinart
Post by Reinart21 »
Otto,
Waar kan n mens so stel kry en hoe moeilik is dit om te maak pas?
The Legend
Real Name: Dawie
Bosfebok wrote:Ouens, doen julleself 'n guns voordat jy jou calipers op 'n 2.2 SFA vervang.. Kry FJ75 disc, KZTE 4 pot calipers en die KZTE master cylinder... als pas mooi en jou bakkie briek soos 'n bom!
Stem saam,dit is die moeitewerd. Ek moet nog net die KZTE master cylinder vir my kry. Weet iemand dalk waar ek een kan kry?
Scott
Vehicle: Hilux SFA
Real Name: Rodney
Post by Scott »
I melted seals on the brake caliper being towed back from sabie a word of advice I am mechanical minded and thought stopping power was up to scratch but if you buy sfa redo all four corners and if you are unsure buy the recons from hoppy or get it done buy break specialist.It cost me R4000 towing fee and then still had fix the breaks.
Bosfebok
Town: Roodekrans
Real Name: Otto
Post by Bosfebok »
Ek het my goed by ouens op die forum gekoop... place net n add onder wanted...dalk kan iemand all die goed as n kit vir jou verskaf...
Discamazing om n 4y met brieke te he... much less fearful!
Otto X248
20.5" LED BAR
90l Water Tank
Slide Drawer System
Safari Snorkel
Diff breathers
Stef
Vehicle: '98 LTD
Real Name: Stefan
Club VHF Licence: X107
Post by Stef »
Goldwagen kan die FJ discs verskaf asook pads (ATE) ons plaaslike tak hou net nie voorraad nie maar hulle kan bestel.
Weet nie v ouer SFA;s nie maar op die LTD kan mens die standaard calipers gebruik, jy moet net 'n spacer maak om tussen die 2 helftes te sit om oor die dikker disc te pas. Blykbaar net soveel pistons as die KZ calipers, kan nie onthou of dit 2 of 4 is nie....
The Legend
Real Name: Dawie
Stef ,die standard SFA het ook 4 pistons per caliper (Twee grotes en twee kleintjies) terwyl die KZTE 4 grotes het.Dus oefen die KZTE calipers meer druk uit op disk pads as die standard SFA calipers.
The Legend
Real Name: Dawie
Die KZTE calipers gebruik ook groter (langer) disk pads as die standard SFA calipers
Stef
Vehicle: '98 LTD
Real Name: Stefan
Post by Stef »
Dankie Oom Dawie :thumbup:
FJ75 discs met standaard calipers en pads werk net so goed; gesien op vriend van my se LTD met 'n Lexus in. Die outjie kan nogal stop as dit moet. Dink nie mens sal daai bietjie verskil in pad lengte agter kom nie; groot geheim is die discs wat koeler bly IMO.
IndianaJones7746
Town: Citrusdal
Real Name: Ben
Is al die Land Cruiser bakkie (80's tot nou) remskywe dieselfde?
Is dit die FJ75 remskywe van die ou 3F enjin Cruiser of is dit dieselfde as die nuwer 4.5P DOHC 1FZ Cruisers?
Stef
Vehicle: '98 LTD
Real Name: Stefan
Post by Stef »
Nee velskoen nou vra j my vas...
Dink daar is 2 variante...maar kan dalk die ou by Goldwagen wees wat dink aan die nuwe FJ 'tjie.
Beste is om maar te meet en pas
Bosfebok
Town: Roodekrans
Real Name: Otto
Post by Bosfebok »
IndianaJones7746 wrote:Is al die Land Cruiser bakkie (80's tot nou) remskywe dieselfde?
Eish, kannie onthou of die manne die 4Y se pads net so terug gesit het en of hulle die KZTE se pads op gesit het nie... ek dink dit was de KZTE se pads...
Otto X248
20.5" LED BAR
90l Water Tank
Slide Drawer System
Safari Snorkel
Diff breathers
The Legend
Real Name: Dawie
Standard SFA remskoene sal nie pas op die KZTE se calipers nie
Thabogrobler
Club VHF Licence: x223
Post by Thabogrobler »
FJ 75 vented disk Midas part number: MVD4276
SFA caliper seal kit Midas part number: Partquip 1054
