Hilux Budget Lifting Kit soon available
- AmadaXtreme
- Town: Centurion
- Vehicle: Fortuner d4d 4x4
- Real Name: Cobus
Hi All
I am busy with the Hilux Upgrade suspension that will give you a nice lift (50mm) and not kill your wallet in the process.
The kit will include the following:
2 x Front AmadaXtreme 2" Up Shocks - these shocks have a raised spring seat thus with the std spring it will raise your vehicle with 50mm
2 x AmadaXtreme Rear Shocks
2 x Set of extended shackles and shackle bushes to raise the rear of the vehicle with 40mm
Note the front will be raised slightly more in order to also level the vehicle.
This complete kit as listed above will be going for R6500 - excl fitment and delivery...... if all goes well will be available from next week.
Note - People asked me why not just fit spacers and just shackles are much cheaper - Yes but adding the perfromance AmadaXtreme shocks are extremely important as the extra high increase the centre of gravity thus the shocks added to the kit will also give your vehicle awesome handling and stability!
Please let me know your thoughts regarding this kit
- $T2eC16J,!zUE9s38-J!IBQTvwDlcvw~~60_1.jpg (18.22 KiB) Viewed 2621 times
- spd_2010051294607_b.jpg (24.49 KiB) Viewed 2621 times
AmadaXtreme Cobus 071 641 7947 or Rory 072 759 2926
Suspensions
Suspensions
- Hilux 1
- Real Name: Tertius
- Club VHF Licence: HC137
Re: Hilux Budget Lifting Kit soon available
Souns like fun, is this for all year models?
- AmadaXtreme
- Town: Centurion
- Real Name: Cobus
This will be for the Vigo +2005 models as the olde models does not have a front coils
However I have AmadaXtreme Performance shocks available for your Hilux
Suspensions
Suspensions
- Masekind
- Town: Lichtenburg
- Real Name: Drikus
Het hierdie ook n sport/comfort opsie?
- AmadaXtreme
- Town: Centurion
- Real Name: Cobus
Vir die agter shocks ja is Comfort & Sport beskikbaar
Maar voor shocks vir die 2005+ net in sport beskikbaar en vir die 99 - 2004 modele is voor net in comfort beskikbaar.
Suspensions
Suspensions
- Maxx
- Town: Fochville
- Vehicle: 05 4.0 V6 A/T DC 4x4, 01 Opel Astra classic, 04 Suzuki Hayabusa GSX-R 1300
- Real Name: Herman
So ek kry std suspensie gemak met die lift by ? wanneer word die eerste stel getoets sal graag wil weet wat die terugvoering is en sal dan beslis belangstel as ek weet dat dit werk
- AmadaXtreme
- Town: Centurion
- Real Name: Cobus
Hi Herman,Maxx wrote:So ek kry std suspensie gemak met die lift by ? wanneer word die eerste stel getoets sal graag wil weet wat die terugvoering is en sal dan beslis belangstel as ek weet dat dit werk
Yip, net shocks en shackles nodig!
Ek het n soortgelyke kit op die Fortuners wat ek self getoets het en al n hele klomp verkoop het - dit werk great! Enigste verskil is die Fortuner vat agter n spacer op die coil spring vs die Hilux se extended shackles op die bladvere
Kit sal volgende week beskikbaar wees
Suspensions
Suspensions
- Town: Kathu
- Vehicle: 2011 Toyota Hilux D/C D4D 4x4
- Real Name: Rudolph
Cobus
Dit lyk goed! Kan ek net die voorste 2 shocks by jou koop of moet ek die hele kit koop? PM my asb met die prys vir net die voorste 2. Nog 'n vraag, mens sal seker nie 'n performance coil bo op die shock kan sit wat reeds 'n hoe spring seat het nie? Dan gaan ek lift met 100mm he!
- AmadaXtreme
- Town: Centurion
- Real Name: Cobus
Hi RudolphWhiteley wrote:Cobus
Ja, jy kan net voor shocks by my kry - ek het twee tipes - Die wat ek in die kit het met n raised coil seat en dan ook shocks wat die spring seat op die oorspronklike plek sit - met ander woorde geen lift gee nie.
Ja as jy n upgrade spring op die 2" up shock fit sal jy heel waarskynlik n 100mm lift kry Het dit nog nie self probeer nie maar dit maak sin, dan sal jy n hele paar verandering moet doen asook n extended ball joint in die boonste control arm.
Die shocks werk R1250 elk - dus R2500 vir (2)
Suspensions
Suspensions
- ForYota
- Town: Gauteng
- Real Name: Hennie
Ek het Otto du Plessis na jou verwys, hy sal jou kontak.
