Free flow for KZTE
- Menthis
- Vehicle: Toyota Hilux Raider Legend 35 3L KZ-TE D/C
- Real Name: Theo
Free flow for KZTE
I would like to have a free flow fitted on my KZTE
has anyone done this recently done this?
Can anyone please let me know where the best place is to have this done at a good price and good quality?
- Town: wellington
- Vehicle: 81 hilux 350,80 vx landcruiser,650 bombardier.
- Real Name: martin
Re: Free flow for KZTE
theo,
don't know where in your area(i am from the good old wc),but it is deffinitly worth the bucks!
any diesel turbo will benefit by doing this.
throw out all the silencers and just fit one small one and at least 63mm pipe right through.
hilux sfa -the only real 4x4!
- Menthis
- Real Name: Theo
hi van
im in joburg
thanks for the advice!
im in joburg
- Menthis
- Real Name: Theo
van
do i have to do branches too?
- grobbepj
- Town: Alberton
- Vehicle: Hilux legend 35 4x4 3.0kzte D/C
Had mine done via steves auto clinic. Very happy and they were on the cheaper options. Probably the best SAC is in centurion... Not too far from you.
- grobbepj
- Town: Alberton
I did not do the branches. Was advised that the kzte branches is very much adequate as is. 65mm pipe from just after the branches to the back.Menthis wrote:van
- JohanW
- Town: Strand
Did a powerflow free flow exhaust upgrade on last week Friday. Turbo spins up much sooner, more power from 1500 rpm onwards. From the turbo to the flex joint I have a 61mm pipe. Seems it came out standard with that. From the flex joint to the back I now have a single powerflow box and a pipe going out just before the rear bumper on passenger side. Total cost was R1600 normal steel. Diesel exhausts don't rust. The diesel soot prevents rust. So stainless steel is an overkill. I took the standard exhaust off in perfect condition. It was 13 years old.
Edit : it's a 63mm system from the flex joint.
- Menthis
- Real Name: Theo
Dankie julle
dit het baie gehelp
dit het baie gehelp
- Town: Jeffreys Bay
- Vehicle: Hilux KZ-TE D/C 4x4
- Real Name: Grant
Where can I have this done in the Jeffreys Bay area? Otherwise in PE?
- pietdevs
- Town: Mosselbay
I'm in Mosselbay and had my free flow done here - excellent job for under R1000. Definitely worth while! Maybe you can drive thru from Jbay and have it done here?
- Real Name: Grant
Thanks, but PE is much closer to Sharks country - have to avoid WeePee land for now!!
Can this be done by a Supa-Quick?
- pietdevs
- Town: Mosselbay
I suppose they have the tools?
- Menthis
- Real Name: Theo
Piet where in Mosselbay did you have this done?
I'm visiting my parents there in Dec and should maybe have it done while I'm there
also could you see the improvement on fuel consumption and power?
- louis fourie
- Club VHF Licence: X101
Hoe weet ek dat ek nie al reeds 'n free flow box op het nie? Kan iemand dalk 'n foto opsit van sy free flow box.
Dankie...wag vir 'n fotie
Nog 'n vraag. Waar anders kan ek 'n free flow laat installeer behalwe Steves. Het klaar 'n prys van hulle.
- 4x4Maniac
- Town: Centurion
- Real Name: Werner
- Club VHF Licence: X120
Hi Louis, ek het by Noise Boys sommer gehoor en hulle vra so R2600 vir n free flow box en pyp in stainless steel.
Sent from my couch using a potato.
ORRA CALLSIGN X120
AKA Epsilon on 4x4Community
(2011 JKUR)
Rugged Ridge Light Guards
KC Spotlights
Previous:
(2011 JKUR)
KC Spotlights
Previous:
- louis fourie
Thanks Werner. Ek sal hulle ook 'n luitjie gee
- Menthis
- Real Name: Theo
Louis
ek het nog 'n plek se nommer gekry by een van die Toyota ouens to ek my bakkie daar gehaad het
hulle vra R2000 stainless voor vat
TNT exhaust 011 822 2121 jy kan met Tom praat
- Pote
- Town: Hartbeespoort
- Vehicle: Fortuner D4d 4x4 & VW Passat
- Club VHF Licence: X228
Jy kan ook by die manne van De-Graaf probeer. Die een in VD Hoff Road het ek al 'n paar van my karre na toe gevat en hulle werk is baie goed...louis fourie wrote:Hoe weet ek dat ek nie al reeds 'n free flow box op het nie? Kan iemand dalk 'n foto opsit van sy free flow box.
- Menthis
- Real Name: Theo
pote
jy vir ons 'n kontak nommer?
Google Theo, google!
- louis fourie
Watse verskil in brandstof verbruik en krag maak die freeflow?
Marginaal!louis fourie wrote:Watse verskil in brandstof verbruik en krag maak die freeflow?
MAAR die EGT's behoort heelwat laer te wees.
