Oil Change
- louis fourie
- Club VHF Licence: X101
Oil Change
I add 500ml of oil every 1000 to 1500 km to my wife's Toyota Avanza. Do you guys think I must drain the oil with a service or is the regular addition enough to keep the oil "fresh"? The oil on the dipstick is nearly transparent.
Sent from my GT-I9300 using Tapatalk 4
- Club VHF Licence: X93-
Re: Oil Change
Louis,
Ek sal die olie saam met oliefilter vervang op sy dienste.Is die olie verbruik nie n nietjie abnormaal hoog nie?
- Thunder02
- Town: East Rand
- Vehicle: IFS Hilux
- Real Name: Neil
- Club VHF Licence: HC105
Re: Oil Change
Was thinking the same,i know they do use oil,but it sounds alot
Scout motto:be prepared....
www.4x4direct.co.za
www.4x4direct.co.za
- Gideonvanzyl
- Vehicle: Hilux 2.7 D/C 4x4
- Real Name: Gideon
Re: Oil Change
is sy ringe nie dalk klaar nie, of het hy dalk n hengse olie lek iewers?
Toyota Hilux 2.7 Legend 35 (Bullnose) 2003 d/cab 4x4 with Cooper Discoverer AT 3's on with unichip and Powerflow exhaust. Name: Blouwillebees
- Thunder02
- Town: East Rand
- Real Name: Neil
Re: Oil Change
It will smoke like a two stroke,if rings are finishedGideonvanzyl wrote:is sy ringe nie dalk klaar nie, of het hy dalk n hengse olie lek iewers?
www.4x4direct.co.za
www.4x4direct.co.za
- louis fourie
Re: Oil Change
Hy rook nie en lek ook nie olie nie. Ek kry so 12.6km/liter gemiddeld
- Vehicle: 1995 SFA
Re: Oil Change
Vra mens vir die Stealers, sal hulle seker sê dis volgens spesifikasie. Ek het vir Mercedes gewerk en ek dink hulle spec was omtrent 500ml/1000km. Belaglik!!
Re: Oil Change
The oil consumption is a little high but not wild or too excessive. I wouldn't worry about it too much, but it is necessary to replace the old oil ..... otherwise you will have a build-up of impurities / contaminants, carbon and acidity. You could perhaps get away with a slightly longer service interval on the oil, but don't leave it indefinitely.
- JEEPIE
- Town: Roodepoort
- Real Name: Shaun
- Club VHF Licence: X 43
Re: Oil Change
is it petrol or diesel ?
- louis fourie
Re: Oil Change
PetrolJEEPIE wrote:is it petrol or diesel ?
- Rebel 4x4
- Town: Port Elizabeth
- Real Name: Thomas
Re: Oil Change
Daai olie verbruik is gans te hoog vir 'n petrol. 'n Vriend wat ook 'n Avanza het gebruik niks olie tussen sy 15 000km dienste nie.louis fourie wrote:PetrolJEEPIE wrote:is it petrol or diesel ?
- Real Name: Marnus
Re: Oil Change
Jy moet die olie en filter elke diens interval vervang. Wat se olie het jy voorheen gebruik. Ek het al gevind dat sekere (goedkoop) olies wel wegbrand. As die kar nie rook en probleme veroorsaak nie sal ek nie daaroor bekommer nie. Geen twee karre is identies nie en sommige gebruik meer olie as ander.
Is daar taai swart aanpaksel in die uitlaatpyp?
