Page 2 of 2
Re: Gomad canopy,kitting project for overlanding.
Posted: Sat Jan 04, 2014 12:48 pm
by Thunder02
Ok,as promised,let's start with bat pack.
Used a strech strap to clamp down,this way it can be easily removed in a camp site.
- Bat pack 2.jpg (232.77 KiB) Viewed 3825 times
I've tried to set up the vehicle with one rule in mind,"if you have to remove something to get to another thing,the system is not working!"
The water tank was fitted to the back wall with the tap mounted on the rear bumper,thus gravity fed and no pumps to pack up.
- Tank 2.jpg (224.62 KiB) Viewed 3825 times
- Tank 1.jpg (216.91 KiB) Viewed 3825 times
It's a 67 L,biggest problem was to find one with the filler cap on the correct side.Also found a really cool hose with which to fill the tank.
- (252.96 KiB) Downloaded 712 times
To be continued.........
Posted: Sat Jan 04, 2014 1:02 pm
by Thunder02
Next was to fit a table,which could be reached easily.
Fitted it under the fridge slide.Was not keen on the idea of having it under the roof rack,which also meant that mamma would have to clean all the bugs off once the campsite had been reached.
- Table.jpg (224.67 KiB) Viewed 3825 times
Behind the fridge is were is store our gas stove and my second kettle,Yip second kettle,sucker for filter coffee
The camp chairs and sleeping bags then get strapped down on the top deck,with the four stretches then slotted next to the fridge.
- Chairs.jpg (257.25 KiB) Viewed 3825 times
Ok so what didn't work,fridge cable and need one shelf in the kitchen unit.Got a plan for the cable and will post pics when done.
Posted: Sat Jan 04, 2014 2:47 pm
by The Legend
Thanx Neil
Looks very good.Like your setup very much
Posted: Sat Jan 04, 2014 2:52 pm
by Thunder02
Lollie wrote:Thanx Neil
Thanks Oom Dawie
Takes time and plenty overlanding trips(not that I'm complaining)to sort out everything,there's always room for improvement.
Posted: Tue Apr 29, 2014 12:22 pm
by 4x4Grant
Wow thats awesome. Thanks for pointing me to this Neil
You must have more updates by now... hehe
Posted: Tue Apr 29, 2014 12:49 pm
by Thunder02
4x4Grant wrote:Wow thats awesome. Thanks for pointing me to this Neil
A few, will get around to posting soon.
Posted: Tue Apr 29, 2014 2:17 pm
by Whisky
Hi Neil,
Your set-up looks good and as you say there is always room for improvement. Every time we come back from a trip we make changes.
Where did you purchase that hose from? I am also looking at something of that nature, no rubber thus no taste in the water.
Thanks,
Posted: Tue Apr 29, 2014 2:23 pm
by Thunder02
Whisky wrote:Hi Neil,
Thanks,
The water tank hose was from a pet shop, used on the aquariums, the water hose was bought at Game, verimark product.
Posted: Tue Apr 29, 2014 8:06 pm
by Whisky
Thanks Neil
Posted: Tue Apr 29, 2014 8:21 pm
by Thunder02
Whisky wrote:Thanks Neil
No problem
Posted: Wed Jul 16, 2014 1:01 pm
by Thunder02
Finally got some odds & sods sorted:
First, make use of wasted space.
- Space saver 2.jpg (61.3 KiB) Viewed 3588 times
- Space saver 3.jpg (58.96 KiB) Viewed 3588 times
- Space saver 4.jpg (44.59 KiB) Viewed 3588 times
Still need to put the floor board in,which will keep it nice and square.
Added a handle to the table,makes life much easier on cold mornings.
- Table 1.jpg (74.81 KiB) Viewed 3588 times
- Table 2.jpg (60.48 KiB) Viewed 3588 times
Posted: Wed Jul 16, 2014 1:09 pm
by CasKru
Like the fridge handles on the table
Posted: Tue Jul 29, 2014 4:09 pm
by 4x4BEES
Looking very sorted Niel
Posted: Tue Jul 29, 2014 5:39 pm
by Thunder02
4x4BEES wrote:Looking very sorted Niel
Solar is the next step,panel sorted,just got to see which way to go with the connection.
Posted: Wed Jul 30, 2014 12:09 pm
by ROOFER
Posted: Wed Jul 30, 2014 12:56 pm
by Thunder02
Charl, strange enough I don't get a lot of dust into the back.I keep the little slide window on the cab side open and it seems to do the trick.You don't want a vacuum to build up in the back.I bought one of those vents from 4x4 Direct which I must still install.
http://www.4x4direct.co.za/shop/canopy- ... -p-307.htm" onclick="window.open(this.href);return false;
Posted: Wed Jul 30, 2014 8:56 pm
by JohanM
Neil,
Very neat setup that you have there and im getting there with mine this year to be finished by december.
Posted: Wed Jul 30, 2014 9:12 pm
by Froll
Looking very nice Niel.
Posted: Thu Jul 31, 2014 7:58 am
by Thunder02
JohanM wrote:Neil,
I keep on thinking that there's only one job left, but no
Posted: Thu Aug 21, 2014 8:14 pm
by Thunder02
Thunder02 wrote:JohanM wrote:Neil,
And on that note, the next project starts. Roof console.
Being wanting to build one for a long time,must haves:
1. place for radio
2. storage for maps and books
3. 3 sets of LED lights.
Posted: Thu Dec 04, 2014 8:05 pm
by Thunder02
Busy installing a solar panel, also fitting a regulator and will eventually upgrade the whole system to a Ctek, I was at national luna's factory during the week and they recon they will have a new battery power pack out at the end of 2015 which will be solar panel compatible.
- Solar 1.jpg (69.08 KiB) Viewed 3318 times
Only problem I've had so far is that when I'm ready to test the sun has gone down
At least i can sit this weekend and take readings.
Posted: Fri Dec 05, 2014 8:49 am
by Masekind
Baie nice sal nog 1 dag myne kry
