I have lost my second set of rear mudflaps, no ways Im getting another set from Toyota.
Any members here have DIY solution?
Where can I get two pieces of conveyor belt?
Mudflap Vigo Shape
Re: Mudflap Vigo Shape
Conveyor belting will do but don't go too thick / stiff ... about 8mm would be the thickest. Cut them a fraction shorter than standard so that they don't foul against the wheel so easily in reverse, and make use of a 'tie-back'. Problem solved.
- stephanvaneeden
- Vehicle: 2012 Hilux 3.0 D4D D/C 4X4
- Real Name: Stephan
Wat het die stealers jou gevra vir 'n nuwe stel. Sit met dieselfde probleem, myne het tussen die band en 'n sandtrack ingekom, so dit lyk of iemand op my geskiet het.
- Jaws
- Town: Sharonlea
- Vehicle: 2009 D4D 4x4
- Real Name: Herman
Ek het dit by Hybrid gekoop op die Forum, ek dink hy het my R400 gevra vir die stel?
Have a look here
- stephanvaneeden
Dankie Andy, gedink ek gaan maar 'n kettingtjie vir elkeen maak, gaan beslis nie na elke trip die goed vervang nie.
- Stan_
- Town: JHB
- Vehicle: 3.0 D4d
- Real Name: Stan
- Club VHF Licence: T35
Stephan i bought a set of Front Mudflaps from Toyota and fitted them to the rear, they're alot shorter than the original rear set. I can take some photos of what i did if you want .
- TOYODA
- Real Name: Tiaan
Ek het ook al 'n paar verloor. Links agter.
Ek het 'n stel gekoop by Toyota en dit net korter gesny. Het nog nie weer een verloor nie, maar dan moet ek ook sê dat die bakkie nou bietjie hoër staan as voorheen.
- Jaws
- Town: Sharonlea
- Real Name: Herman
Sounds like good plan thanksStan_ wrote:Stephan i bought a set of Front Mudflaps from Toyota and fitted them to the rear, they're alot shorter than the original rear set. I can take some photos of what i did if you want .
