Freewheel Hubs Making a funny noise - IFS
- 4x4 Junkie
- Vehicle: Hilux 3.0 D-4D 4x4 DC A/T
- Real Name: Julian
Hi Gents,
I have been dreading writing this post at the thought of what the resultant advise might be, but I cannot leave it any longer - it's eating at my nerves.
I have a 2002 3.0 KZ-TE with 250000km on the clock. It is in overall good mechanical condition and has never let me down. During my trip to Limopo and Lesotho in December, I noticed a sound from the freewheel hubs when drive on corrugated roads. It makes a "click" sound. I have heard the same sound before after using the 4WD system when disengaging after a trail or the like.
The fact that I now hear this "disengaging" sound when the system is engaged and when driving gravel/corrugated roads, leaves me to worrying about how to remedy the problem (if it is a problem). I did a quick test at home over the weekend; I jacked the car up and put bokkie stands front and rear - engaged 4H and 4L and the 4WD systems engages fine.
Can someone maybe share some personal insights or mechanical advise on what may be the cause of this and if it is anything to cause concern?
If you still have blank pages in your passport, it's probably time for a road trip.
- Blitzkrieg
- Town: Glen Marais
- Vehicle: 94 Hilux D/C V8 Lexus. 2009 LC Prado 4.0 V6
Re: Freewheel Hubs Making a funny noise - IFS
Hi Julian,
I removed my SFA's hubs and found that the spring separated from the holding plate.
If you decide to remove the hubs be carefull when removing the cotters (just behind the nuts and washers), a light tap with a hammer on the side of the hub should loosen them up. They are very expensive from Toyota and hard to find.
I have a picture somewhere of the hub when I removed it, will see if I can post it for you.
- Blitzkrieg
- Town: Glen Marais
This is the only pic I have, sorry Julian.
Hopefully it's not a major failure.
- 4x4Maniac
- Town: Centurion
- Real Name: Werner
- Club VHF Licence: X120
Hi Julian, from the description above it doesn't seem to actually disengage, or do I have it wrong?
Have you considered the clicking noise is perhaps from the pads, maybe some Copper grease on the anti-rattle plates so they don't Rattle? Also check all the split pins.
If you need to open the hub and it is the spring inside, the cone washers can be pulled out by hitting the bolts with another bolt and nut screwed on the loose bolt, that way the cone washers will just pop out. Examine the hub spring.
Hope that makes sense...
ORRA CALLSIGN X120
AKA Epsilon on 4x4Community
(2011 JKUR)
Rugged Ridge Light Guards
KC Spotlights
Previous:
(2011 JKUR)
KC Spotlights
Previous:
- 4x4 Junkie
- Real Name: Julian
It is definitely not the squeak plates on the brakes that is making the noise, that is very familiar sound and I have changed the brakes many times myself.
From what I could establish, the 4WD system does engage and remains engaged, but I get that clicking sound while driving.
- Blitzkrieg
- Town: Glen Marais
- 4x4Maniac
- Town: Centurion
- Real Name: Werner
Does it make a clicking sound when going straight or more prominently when turning whilst in 4x4? Could it perhaps be the inner CV's if going straight or outer CV's when turning... Otherwise what about wheel bearings? I can't think anything is wrong with the hubs, it's a simple has a simple function. It connects the wheel hub with the splines of the stub axle, which is connected to the front diff, so it has to be either CV's or inside the diff.
ORRA CALLSIGN X120
(2011 JKUR)
KC Spotlights
Previous:
(2011 JKUR)
KC Spotlights
Previous:
- Blitzkrieg
- Town: Glen Marais
I also suspect wheel bearings, then it should make that sound even in 2x4.
If you decide to replace wheel bearings I suggeset Timken.
A quick check to do is lift up the front wheels and check end play.
- Pietman
- Vehicle: 2005 Hilux V6 4L D/C 4X4
Hi Julian
Are you sure it is the front hubs that are making the noise and not your front diff?
I had my front diff making almost the same sound, only when 4x4 was engaged. End result was front pinion had 3 pins broken off.
But hopefully yours is not the same.
Regards
Pieter
Regards
Pieter
EX ALTO VINCIMUS
- 4x4 Junkie
- Real Name: Julian
I have heard the sound when in 2x4. I really hope it's no diff related. Then we're talking serious $$$$ ... and out the window goes my theory that Hilux's are cheap to maintain
- Pietman
If you have heard the sound in 2x4 you can count diff related problems out. The front diff I think will only be noisy when 4x4 is engaged. That was my problem. Everytime I engaged 4x4 the ticking sound would start... Like a timebomb
EX ALTO VINCIMUS
- 4x4 Junkie
- Real Name: Julian
Maybe it could then be wheel bearings or the hubs. I checked out some video tutorials on youtube over the weekend, doesn't seem to difficult to clean and service. My lux is in this week to get some cosmetics done. I'll tackle the front axle next weekend.
- Pietman
Good luck, i will hold thumbs for you
EX ALTO VINCIMUS
- george
- Town: Velddrif
- Vehicle: Triton 3.5l V6
- Club VHF Licence: HC107
My hubs are also doing the clicking sound when disengaged. :alvarin: For now I drive with the hubs in the lock position and the sound is gone. Hoppy can sort it out when I am back Lets hope it last to then
- ForYota
- Town: Gauteng
- Real Name: Hennie
Julian, i had the same thing when 4wd engaged in low. When i turned to the right it sounded exactly like a worn cv... I also knew that my wheelbearing was kapoet.. Changed the bearing and gone is the noise..! Funny enough is i didn't have play on the wheel.
- 4x4Maniac
- Town: Centurion
- Real Name: Werner
If the sound is there when in 2x4 hubs locked it could be front diff, bearing inside the transfer or front prop. If the sound is there when in 2x4 hubs not locked it can only be a wheel bearing.
M2cw
M2cw
ORRA CALLSIGN X120
(2011 JKUR)
KC Spotlights
Previous:
(2011 JKUR)
KC Spotlights
Previous:
- 4x4 Junkie
- Real Name: Julian
Thanks guys. I will work on a process of elimination starting with the cheapest first.
George I also spoke with Hoppy and if I don't get it resolved on my own, I will take it to him
- george
- Town: Velddrif
Hi Julian.Just a quick update on my Hubs. I finally took the plunge and opened up the hub. My clicking sound come from the fact that my clutch assembly is a bit wear out. When I am in the "free" position the gear is not completely withdrawn.I would say about 95%. So basically when I drive the gear is still touching the shaft very lightly. I tried cleaning and greasing but it is still there.A bit better but still touching.For now I am just going to drive with the hubs locked till I can get a new hub.I hope this kind of make sense :alvarin: It took me a while to figure it out.
- 4x4 Junkie
- Real Name: Julian
Thanks for the feedback George. I hope you don't have to sell a kidney to afford those new hubs.
I will update progress as I go along
- george
- Town: Velddrif
Nah the freewheel hub is about R1500 IIRC,but I only need the clutch assembly.4x4 Junkie wrote:Thanks for the feedback George. I hope you don't have to sell a kidney to afford those new hubs.
