Hi guys, can someone give me the diff ratios for a 1991 4Y hilux double cab, its standard and not an import,
cheers
Stubs
Diff ratios
- Town: Pretoria-Mayville
- Vehicle: 1992 2.2-EFI Hilux 4x4 with Maus conversion,freeflow,Rear Electric Locker'2005 BMW 320i, 2015 Hilux 3d4d dc 4x4
- Real Name: Marius
Re: Diff ratios
Ek dink 4.875 weet nie of dit 'n verskil maak as dit 'n import of local diff is nie?
- LouisZ
Re: Diff ratios
4.875 .
Re: Diff ratios
Front diff is an import diff. Rear diff is either import or local, but both have the same ratio (4.875). If the rear diff has a removable rear cover, it's local. If the cover is welded in place it's import. The import diff is removed in it's entirety (one assembly) from the prop-shaft side and is known as a 'third member'. Rear and front third members are interchangeable .... they are exactly the same.
Benefits of the import is that they are more robust IRO crown & pinion and have 30 splines on the half-shafts as opposed to 27 on the local Gearmax diff. Also, a third member can be set up on the bench (backlash / pre-load) which is much easier than setting it up in-situ.
