Some questions for a new Fortuner owner
ronnie
Town: Durbanville
Vehicle: Totota Fortuner 2006 4.0 V6 4x4; Long Range fuel tank; AmadaXtreme suspension; C-Tek D250S dual battery system
Real Name: Ronnie
Club VHF Licence: HC 141
Post by ronnie »
I just recently sold my Hilux 2x4 and bought a 2006 Fortuner V6 4x4; and I'm loving it !!! I have a number of questions as I don't want to make the mistake of adding accessories or kitting out and then finding out afterwards it wa the wrong thing to do.
First of all, the 2006 models were some of those that had some lets call it stability issues. As I will also be towing a road caravan with the car I want to not take any chances. For overlanding trips I won't be loading too heavy so don't think a full suspension upgrade is necessary. Would the addition of airbags at the back help with towing the caravan and help with stability? If not is a full suspension upgrade the only way? Decent tyres will be the first thing to happen.
Has anyone fitted a packing system that can be removed when you need the third row of seats? I will sometimes need the third row but when overlanding I wopuld want to remove the third row. Any pics would be great...
As far as tyres are concerned do I stick with the 265x70x16 or do I go a bit bigger? The Fortuner already has an extra tank so the spare wheel is quite low; bit worried it may drag in thick sand.
Any help will be appreciated.
Ronnie
Re: Some questions for a new Fortuner owner
Post by OOOOMS »
Hi Ronnie and welcome :thumbup:
With my wifes Tuna and towing an off-road trailer I could clearly see the problem. Rear was hanging and decided to fit air suspension! Best thing I ever spent money on. You can load a ton and still level
:!: With standard suspension still in.
Handling is better than before as the Tuna feels nice ans stable on the long road.
From day one I fitted BF All Terrain 265 / 75 / 16's. Never had a problem until we fitted a winch and bumper. Fitted 16mm spacers and on top of coils and this sorted the froblem out when turning as it catches the mudflap ever so slightly.
IMG_0002 (Small).JPG (53.29 KiB) Viewed 3493 times
ronnie
Town: Durbanville
Real Name: Ronnie
Post by ronnie »
Thanks OOOMS...very helpful indeed. Do you think the airbags will have the same effect towing a road caravan where the issue is not so much weight on towbar but more the sheer size of the caravan; I tow a 6.5m caravan :shock: and if the wind picks up you know about it. We use a stabiliser which helps a lot but I am probably just a bit more cautious due to the number of roll overs with Fortuners towing caravans. Should the air bags make the rear more stable on the whole?
Ronnie
Post by OOOOMS »
ronnie wrote:Thanks OOOMS...very helpful indeed. Do you think the airbags will have the same effect towing a road caravan where the issue is not so much weight on towbar but more the sheer size of the caravan; I tow a 6.5m caravan :shock: and if the wind picks up you know about it. We use a stabiliser which helps a lot but I am probably just a bit more cautious due to the number of roll overs with Fortuners towing caravans. Should the air bags make the rear more stable on the whole?
Ronnie
I would say abserlutely :thumbup: :thumbup: :thumbup: Best thing was the cost of having them fitted, suited my pocket!!!
ronnie
Town: Durbanville
Real Name: Ronnie
Post by ronnie »
Awesome...exactly what I was hoping to hear. Have you fitted a packing system in your Tuna or do you use the third row of seats?
Post by OOOOMS »
ronnie wrote:Awesome...exactly what I was hoping to hear. Have you fitted a packing system in your Tuna or do you use the third row of seats?
No just permanently have the seats removed. Packing is a bit of an issue in the back, so that is why we use the DC :thumbup: OR tow a trailer.....
ronnie
Town: Durbanville
Real Name: Ronnie
Post by ronnie »
Ok thanks for all the info. At first glance i cant see how a removable packing system can work but i will be patient and see if someone has had some success
Hoppy
Vehicle: Hilux SFA & IFS
Real Name: Allan 0721291160
Post by Hoppy »
Bel vir Petrus, hy is in Brackenfell, sy v6 Fortuner het alles op wat jy wil doen. o82 564 6499
Petou
Vehicle: Fortuner 4.0 V6
Real Name: Petrus
Post by Petou »
Ronnie
Jy is welkom om my te skakel en na my voertuig te kom kyk.Ek is in die omgewing en kan dit reel vir na ure ook.
0825646499 Petrus
Snorkel,chip,burnco front bumper
Post by OOOOMS »
Petou wrote:Ronnie
0825646499 Petrus
Petrus, kan jy dalk 'n paar pics laai van jou setup en hoe jy dit gedoen het?
ronnie
Town: Durbanville
Real Name: Ronnie
Post by ronnie »
Dankie Petrus, ek sal graag wil sien hoe dit lyk.
OOOMS, what brand of air suspension did you fit in the Fortuner?
Post by OOOOMS »
ronnie wrote:Dankie Petrus, ek sal graag wil sien hoe dit lyk.
Fitted Air-Springs supply, Firestone
http://www.assc.co.za/" onclick="window.open(this.href);return false;
ronnie
Town: Durbanville
Real Name: Ronnie
Post by ronnie »
Hi OOOMS
Suddenly realised I never asked you whether you need to install air suspension all round or just in the rear :confused: Probably a stupid question but I don't know much about air suspension. Just know that with the pickups you only need to install in rear...
Post by OOOOMS »
ronnie wrote:Hi OOOMS
You can install all round, however we opted for the rear only.
There are a couple of 'fitting' options available. We chose the 'one valve' system. Where you pump up the air bags that are joined with a t-piece. Was the cheapest and most practical imo.
You can have an on board gauge with built in compressor with switch but once again not worth the extra moola's.
x2 airbags rear was around R3k 2.5 years ago, fitted.
ronnie
Town: Durbanville
Real Name: Ronnie
Post by ronnie »
Great, thanks for the help. Will get pricing for 2 x rear airbags...
Post by OOOOMS »
Ronnie, there is a nice article in the WegRy August 2011 edition, bladsy 60
