KZTE EGT gauge/sensor fitment in CPT
Tsa
Town: Durbanville
Vehicle: 2010 Toyota Fortuner 4x4
Real Name: Richard
Post by Tsa »
Hi Guys
I am planning on keeping my lux for a few more years and would like to go the EGT monitoring route.
Any of you have the turbologix system installed, any feedback? What about other brands?
Do you know of anyone in CPT area that fit these gauges/sensors? Not 2 happy with diy drilling into engine block/manifolds, etc tec :shock:
Polarbear2008
Real Name: Theunis
Club VHF Licence: X49
Re: KZTE EGT gauge/sensor fitment in CPT
Post by Polarbear2008 »
Hi Richard
I would try Cris from R&D Offroad first. I great guy with a great team behind him, who can make anything word!
R&D OFFROAD CC
UNIT 10 & 11 GLOBAL BUSINESS PARK
41 GEMINI STREET
BRACKENFELL, CAPE TOWN
TEL: 021 982 8921 / 021 981 8279
FAX: 021 982 8939
Contact: johan@randdoffroad.com
Contact: cris@randdoffroad.com
GPS: S 33° 52.540'
E 018° 42.204'
Monroe Gas Magnum shocks
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
Tsa
Town: Durbanville
Real Name: Richard
Post by Tsa »
Thanks Theunis, I'll start there and see what the guys say. :)
cruiserhj60
Town: Edenvale
Vehicle: Hilux 2.7 DC
Real Name: Trevor
Post by cruiserhj60 »
The Landcruiser Club folks in the Cape swear by Johan Meyer for all their work.
Johann Meyer
S33.93453 E18.60391
021 9treetree 424
Regards
Trevor
Tsa
Town: Durbanville
Real Name: Richard
Post by Tsa »
Morning All
OK, after some research I have found my local Hilux Hero Hoppy willing to fit the EGT probe at a fraction of the price I was quoted at the other places.
Now the next step is to decide on which unit. I am only interested in monitoring EGT (Volts are a bonus).....
http://www.turbologix.co.za/" onclick="window.open(this.href);return false;
Turbologix Base one which just shows EGT @ R1370 (incl Probe)
Pro: Small gauge.
Con: Only EGT reading?
http://www.madman.co.za/EGT1.pdf" onclick="window.open(this.href);return false;
Madman EGT1 (incl probe) @ R1220which shows EGT + Volts
Pro: Voltage reading.
Con:Not as nice to fit gauge. Would most likely be on dash somewhere where I can see it.
http://www.mglavionics.co.za/" onclick="window.open(this.href);return false;
MGL AVionics TC-1 (incl probe and 2m lead) @ R1640
Pro:Has 4 channels.
Con:L Same as Madman wrt fitment of gauge.
Anyone who currently have these systems have any input regarding this choice.
Those of you who have the Madman or the MGL, how and where did you fit it? Wonder if there is a housing one can put the unit in and then fit in the corner of the driver side dash next to the pillar.
TurboLogix2
TurboLogix2
MGL - Avionics TC1
MGL - Avionics TC1
TC-1 small.jpg (9.44 KiB) Viewed 3422 times
TurboLogix1
TurboLogix1
MADMAN EGT1
MADMAN EGT1
louis fourie
Club VHF Licence: X101
Post by louis fourie »
Richard
Look at my thread (viewtopic.php?f=3&t=16677" onclick="window.open(this.href);return false;).
The Madman that I have fitted (looks the same as the one in your photo) has EGT, Water Temp, CLD - Coolant level detection, Oil Pressure, Oil Temp, Volts, Hour meter. EGT, Water Temp and the CLD is the most important for me.
It has an audible alarm with a light warning. I can see it through my steering wheel. The nylon piece that they give you to fit the temp sensor and CLD is rubbish - it keeps on leaking. I have one made out off brass. Have a look at - viewtopic.php?f=3&t=20306" onclick="window.open(this.href);return false;
Tsa
Town: Durbanville
Real Name: Richard
Post by Tsa »
Dankie Louis
Ekt vergeet van jou thread en waar jy hom gefit het. Ek sal bietjie kyk hoe lyk my view daaikant toe en dan miskien sommer ook vir die opsie gaan.
Die gauge waarna ek kyk doen slegs EGT en Volts (EGT1 gauge), dink die ene wat jy het is die EMS2 model en kan heelwat meer inputs vat?
louis fourie
Richard
Jy is reg, ek het die EMS2. Jou water temp meter in die Lux is glad nie akkuraat nie. Dit is veral interessant om te sien wat jou EGT doen hoe hoër jou water temp is (direk eweredig aan mekaar - m.a.w hoe hoër jou water temp hoe hoër jou EGT).
Die CLD is vir my belangrik. Ek het my Lux se head gekraak omdat my radiator gelek het. Nou het ek ten minste 'n waarskuwing.
Wat ek hou van die EMS2 is dat jy die boonste en/of onderste limiete self kan stel waar die alarm moet aangaan. Die paar rand ekstra was vir my die moeite werd om te betaal. Ek glo en hoop ek sal nie gou weer geld aan so 'n monitering sisteem te spandeer nie.
Groete
Tsa
Town: Durbanville
Real Name: Richard
Post by Tsa »
Thanks Louis, wat jy se maak baie sin.
Enige rede hoekom jy nie vir die EMS1 gegaan het ipv EMS2 nie?
Van wat ek kan sien op die tabel is hulle baie dieselfde in stats, nou nie look nie.
http://www.madman.co.za" onclick="window.open(this.href);return false;
louis fourie
Tsa wrote:Thanks Louis, wat jy se maak baie sin.
Richard
Die EMS1 was net te groot, en ek het nie 'n idee gehad hoe om hom te mount nie. Die EMS 1 lyk net te "lomp" vir my.
Tsa
Town: Durbanville
Real Name: Richard
Post by Tsa »
100% dankie Louis, waardeer die inputs.
louis fourie
Tsa wrote:100% dankie Louis, waardeer die inputs.
My Plesier :thumbup:
