What is the best place to install the radio if you use it every. Can you hide it or make it removable?
LTF is going to put it in a centre console in his bakkie, but will this work for a Fortuner.
VHF Kirisun PT8100 in Fortuner
- Vehicle: Fortuner 3.0 D4D
- Real Name: Coenraad
- Club VHF Licence: X103
Coenraad
Re: VHF Kirisun PT8100 in Fortuner
Hi and welcome
Do a search on GertC post, he did a neat installation in his Tuna
- louis fourie
- Club VHF Licence: X101
Hallo Coenraad, en welkom by die forum. Niemand gaan weet wie is LTF nie
Welkom Coenraad. Jy kan daai radio enige plek installeer solank jy ordentlike krag en die aerial draad daar kan uitkry. Jy kan hom nie van 'n standaard sigarette lighter socket af krag gee nie.
Dankie OOOOMS, CasKru and Louis Fourie aka LTF aka Louis "Tungsten" Fourie.
Ek sal maak my clever vrinne i.e. Tungsten vra vir hulp, aangesien hy so 'n goeie werkie van my nuwe Rocksliders gaan maak - kyk uit vir die foto's wat volg
Coenraad
Hi Coenraad, could not find the link myself yesterday but today.....1st time
Here is one of the neatest installations I have come across on a Tuna: By Gertc
viewtopic.php?f=102&t=6257&start=60" onclick="window.open(this.href);return false;
Thank you OOOOMS, I like the fact that the radio is concealed but see from the post that the mic might be a problem (although the other positions in the article had the same problem with where to put the mic).
I also like what he has done with the aerial very neat! Tungsten - weet jy hoe om daardie draaitjies by daai gat uit te kry??
Coenraad
- louis fourie
Coenraad21 wrote:Thank you OOOOMS, I like the fact that the radio is concealed but see from the post that the mic might be a problem (although the other positions in the article had the same problem with where to put the mic).
Ja, jy boor 'n gat deur die dak, druk die draad deur en silicon hom agterna
