KZ-TE RPM
- warrenaken
- Town: JHB
- Vehicle: 3.0 KZ-TE 4x4
- Real Name: warren
- Club VHF Licence: X04
KZ-TE RPM
I need someone to do a little test for me please.
You hear people saying you should not push a 1kzte engine past 2500rpm on the open road, so i was wondering at what speed are you guys travelling for this.
If i do 110km/h on the dash, that is a GPS speed of 106km/h, then i am below 2500rpm. If i go up to 109km/h (GPS) then i am touching 2500rpm.
31x10,5, canopy and draws, SAC intercooler and conversion.
Toyota Hilux KZ-TE
- Vlak vark
- Town: Phalaborwa
- Real Name: Nico
Re: KZ-TE RPM
On mine, 2500rpm is where the turbo starts to boost.
The person that you must talk to is Louis Fourie.
He has al the gadgets on and can tel you about the exhaust temp and revs.
- louis fourie
- Club VHF Licence: X101
Re: KZ-TE RPM
Warren
I have more or less the same setup as you, i.e. 31X10X15, IC and Chip. The important thing to measure is not revs/speed, but EGT (Exhaust gas temperature). I am running cooler with my IC and chip than before. At 120km/h (115 GPS speed) I am running 50°C to 100°C cooler on my EGT at 120km/h with the IC and chip. Even when going uphill at 130km/h I am running just over 600°C.
The EGT must not run over 650°C but for short periods can go to 704°C - internet info when I had problems with my cylinder head.
It will be interesting to see what Dylan's (AM Racing) comments are - he knows a lot more than I do.
Hope this helps
Hope this helps
- JohanM
- Town: Meyerton
- Vehicle: Prado 120 4.0 V6
- Club VHF Licence: HC126
Re: KZ-TE RPM
EGT is very important to measure on any turbo diesel engine as that is a very accurate indication of how things are running under the hood!!!!
- Niel
- Real Name: Niel
Re: KZ-TE RPM
I was always told do not push the rev's past 3000 rpm but I agree what Louis said.
- warrenaken
- Town: JHB
- Real Name: warren
Re: KZ-TE RPM
That makes sense.
I have read a few posts with mention of EGT sensors, but the prices seem a bit steep. Will do some more serches and reading.
Toyota Hilux KZ-TE
- Town: Durbanville
- Real Name: Richard
Re: KZ-TE RPM
Very interesting stuff :) I'm also with Neil and was told also to always try and keep it below 3000rpm.
Sometimes wonder if it is just me, but with the KZ I'm constantly worrying if something is going to "break", but have come to realise its just me not being familiar with a Diesel engine at all.
Unfortunately it does take something away from the driving pleasure and reading all the scary threads does stick in the back of my mind.
- louis fourie
Re: KZ-TE RPM
Warren/Richard
That is why I fitted an EGT guage - it puts the pleasure back into the driving . The best value for money that I could get was the Madman EGT guage at http://www.landyonline.co.za/" onclick="window.open(this.href);return false;. The cost was ±R3400 sensors included (EGT, water, oil temp, oil pressure sensors). It then also measure your battery/charge voltage, hours that your engine is running and it can indate your CLD (Coolant level detection). It earth through the water in you cooling system, so when the coolant level is too low then - wallah - an alarm .
And by knowing all this, I hope/believe that I have a pre-warning system in place.
Re: KZ-TE RPM
Hi Richard,
My cruising speed is around 140 on the speedo, about 128 on the GPS. Revs is just under 3000 and I've been driving it like that for close to 300 000km and not a single problem at all!
Also has SAC intercooler and chip.
BUT high EGT's are a result of wide throttle openings at low RPM's, so under 2000RPM you have to shift to a lower gear.
My 17degrees worth!
My 17degrees worth!
- J.C Avis
- Town: Otjiwarongo
- Vehicle: 2002 Toyota Hilux D/c 4x4 3.0 KZ-D-4D. Suspencion lift,160 liter spare tank. Navigator spots. Double battery system. Tour 'trallies'. Spare wheel carrier. Roof rack. Canopy.
- Real Name: Japie
Re: KZ-TE RPM
Ek het dieselfde ervaring,bo 3000 revs is redelik baie van jou torque weg en dis jou maks kw. My ervaring is tussen 2300 en 3200 revs wil hy bly.Ek hou hom ook so op 2800 revs op langpad. Het op 200 000 km n turbo vervang,vanes was geslyt,die sensor op die intake was nie trug gesit met die service nie,het fyn stof ingekry. Het dit gelukkig raakgesien. Die engin het 220 000km op en geen olie verbruik nie en vol krag! Ek dink sterk aan n vvt-i lexus engin.... Mens is net so bietjie beperk met n diesel engin.
J.C Avis
Re: KZ-TE RPM
Nee man! Moenie 'n goeie trok nou opvoeter nie!J.C Avis wrote: Ek dink sterk aan n vvt-i lexus engin....
- J.C Avis
- Town: Otjiwarongo
- Real Name: Japie
Re: KZ-TE RPM
Loop op papper bande!
Of verkoop en koop 'n 2.7...
- J.C Avis
- Town: Otjiwarongo
- Real Name: Japie
- Town: Durbanville
Re: KZ-TE RPM
Thanks Thabo/JC
@Thabo: My styl is presies dieselfde, op langpad cruise ek teen 135-140km/h wat = 125-130km/h op gps. Dan is my rpm ook net onder 3000 en het nog altyd net reg gevoel.
In general it just doesnt feel right (sukkel) when lower than 2000rpm so my natural feeling is to shift to a different gear anyways.
- 4x4Maniac
- Town: Centurion
- Real Name: Werner
- Club VHF Licence: X120
Re: KZ-TE RPM
Hi Louis,
Het jy enige raad vir wie dalk n EGT guage vir my kan insit. Het onlangs my head vervang en wonder net hoe dinge regtig lyk nou na die nuwe AMC head. Wil nie weer dieselfde excercise gaan nie
ORRA CALLSIGN X120
AKA Epsilon on 4x4Community
(2011 JKUR)
Rugged Ridge Light Guards
KC Spotlights
Previous:
(2011 JKUR)
KC Spotlights
Previous:
- louis fourie
Re: KZ-TE RPM
Wernerwbisschoff wrote:Hi Louis,
Ek het myne self ingesit. Probeer Headzone in Centurion.
Groete
- 4x4Maniac
- Town: Centurion
- Real Name: Werner
Re: KZ-TE RPM
Sal hulle probeer, dankie, net eers weer bietjie moola bymekaar maaklouis fourie wrote:Wernerwbisschoff wrote:Hi Louis,
Groete
ORRA CALLSIGN X120
(2011 JKUR)
KC Spotlights
Previous:
(2011 JKUR)
KC Spotlights
Previous:
- Vehicle: 2002 face lift KZ-TE DC. Mod’s / dual batter - kinda ;) / Active suspension / Intercooler / free flow / ECU Chip / sports flow air filter
- Real Name: Martin
Re: KZ-TE RPM
Volgens my dyno is my bakkie se peak power 2700/2800rpm.
As ons lang pad ry, sit ek baie gemalklik net oor die 3000rpm. Ek dink die intercooler maak 'n
baie groot verskil met die turbo. My issue weer is as ek telank hier by die 3000 rpm gery het,
voel ek dit as ek weer brandstof in gooi - is nogsteeds better as die 2700 bakkies.
Net een ding, as jy aan kom of voor jy die bakkie net af sit - los die bakkie aan vir net so 'n min voor jy net af sit.
Ek doen dit al van dat ek die bakkie het, en ek staan al op 250 000km - geen issues nie.
One Africa, One Hilux needed :)
