Hi all!
Can anyone correct me if I'm wrong. Is it possible to move the rear diff lock to the front diff in a 3.0 d4d 4x4 and install a LSD in the rear diff? The reason I'm thinking it might work is a diff lock doesn't help unless it is in 4L and the lock is engaged. If you have a LSD in the rear it will give you more traction in case of wheel spin for example on hard slippery surfaces like town driving. And also in off road conditions. When driving off road you can engage the front diff lock and the LSD will do it's part. Will it work? And is it worth it?
Move rear diff lock to the front diff?
- jacques kotze
- Real Name: Jacques
- Hoppy
- Vehicle: Hilux SFA & IFS
- Real Name: Allan 0721291160
Re: Move rear diff lock to the front diff?
Good idea in theory, but your front and rear diffs are different sizes, the front one is much smaller and the front CV joints breaks if a front locker is fitted
- Fred79
- Town: Kent UK
- Vehicle: Toyota Hilux Icon 2.4
- Real Name: Frikkie
Hi Jaques
Ek kan nou nie jou vraag beantwoord nie maar indien jy die ombouing kan doen dink ek dit sal nie regtig die geld werd wees nie. My bakkie het LSD en ek kon nog nie 'n verskil voel op gladde nat paaie nie. Wat jy kort is "traction control" dit maak wel 'n verskil. Die top spec Hilux kom hier by ons met traction control uit en ek het so een getoets bestuur en het probeer om hom te te laat gly om die verkeersirkel toe dit nat was en hy het baie ge-grip.
Ons kry nou weer glad nie "diff lock" in die 3.0 modelle nie, net in die 2.5's.
- jacques kotze
Thanks Allan, When you say the front cv joints will brake when using a front locker, what mod should be done to make the cv,s handle the strain? the reason I ask is, I know and heard of a lot of people some on the forum who installed a front locker and as far as I know they didn't make any changes to the cv,s? ThanksHoppy wrote:Good idea in theory, but your front and rear diffs are different sizes, the front one is much smaller and the front CV joints breaks if a front locker is fitted
- jacques kotze
Dankie vir die info Frikkie, Ek was nie regtig van plan om die ombouing te doen nie. Ek het net al baie daaroor gewonder en gedink ek vra bietjie op die forum oor hoe dit sal werk en of dit ooit sal werk. Nou hoef ek nie meer te wonder nie, Dankie vir jou infoFred79 wrote:Hi Jaques
- AM Racing
- Real Name: Dylan
For the Vigo shape I would do a LSD up front because of the cv joints. there are heavier duty cv's available from the land of OZ but $$$! There is no give in a locked diff and cv's WILL break on impact. The SFA is not so much of a problem as they dont have cv joints......
- Christian Kuun
- Town: Stellenbosch
- Vehicle: 2008 Tuna V6 4x4 Manual
- Real Name: Christian Kuun
I was also going to the only mod that would make the CV's last would be a SAS. Then a locker would be lekker!
Wynkop Kuun
O82 6l5 8lO5
O82 6l5 8lO5
