What test - when is a knive sharp enough ?
- Town: Centurion
- Real Name: Everdt
I should have put it under "workshop" - this tool is heavy. I got a "Rambo jnr" 300mm long, 7mm at the top blade with the following details on the blade - * RODGERS SHEFFIELD ENGLAND with some other numbers on the other side. Now my question is how do I sharpen it to last ?
Re: What test - when is a knive sharp enough ?
Some knife shops will sharpen it for you for R20.00(they usuallt send it away), it's well worth it, or even the guys that make knives.
Sounds like a Joseph Rodgers then?
Yep, the Sheffield was the give away!
A few decades ago if you had a JR you where just the man!
- Town: randfontein
- Vehicle: quashqai
- Real Name: mike
Ek gebruik die Landsky Maar maak elke kand ewereedig skerp
- warthog
- Town: Barberton
- Vehicle: Fortuner 4.0 V6 Auto, LRFT, Dual Batt, OME's, BFG AT's, ARM comp, 800w inv, Roofrack
- Real Name: Hennie
When is a knife sharp? (it's either sharp, or it's not- I was taught there's no "enough")
When you rest the cutting edge of the blade on your thumbnail without any pressure, and slightly draw it across. It should leave a cut.
I do all my own sharpening.Some knife shops will sharpen it for you for R20.00(they usuallt send it away), it's well worth it, or even the guys that make knives.
- blom
- Town: Landrovia
- Real Name: Blom
if the knive is a real JR the steel will be higher in carbon than normal
(that is why they rust)
it will give the knive a VERY sharp edge however it will not last that long
so to sharper the JR we usualy give it 2 edges
one (for a lack off a better word) low on the lansky sharpner, and the final as high as possible ie about 30 degrees
it will render the blade sharp (enough) but the edge will last
keep the blade oiled !!!!!(gun oil mixed with castor oil was what the "old people" said )
do not use a water stone to sharpen
Grensvegter van LANDROVIA
- Club VHF Licence: X93-
When you can cut your arm hair.
- Town: Centurion
- Real Name: Everdt
What is the reason for being so heavy ? So far there is no rust, ok it's not getting used acually.
This no is on the other side 27C2360^ ( the last one is an arrow ). Any meaning ?
Do some research and see if they were ever issued to military personnel. The fact that it has a serial no could be explained by this. The arrow on British military hardware used to signify "Retired out of service" .... without such a proof mark it would have been illegal for a civilian to have in their possession.Bulletjie-3 wrote:What is the reason for being so heavy ? So far there is no rust, ok it's not getting used acually.
- Hoppy
- Vehicle: Hilux SFA & IFS
- Real Name: Allan 0721291160
I was shown by a professional many years ago; hold the knife with the cutting edge upwards and towards a lightsource, the shiny bits on the cutting edge are blunt spots, a perfectly sharpened knife will have no shiny spots.
I use a Lansky sharpener, you clamp the knife into a holder and you can descide what angle you need on either side, sharper angles goes blunt sooner.
- oxydog
- Real Name: Jarus
- Club VHF Licence: J67
The angle at which you should sharpen it, depends almost completely on the application. This can vary from 17 degrees for razor-like sharpness, to 30 degrees for heavy duty work, like cutting cardboard. A good angle to try for everyday use, I've found, is 20 degrees.
Bees (Toy)
'98 Hilux 2.8D 4X4 D/Cab
• ARB Bullbar
• Safari Snorkel
• GearMax Rear Locker
• Front Runner bakkie slide
• 31" BFG KM2's
'06 Hilux 4.0 V6 4X4 D/Cab
• Level-it kit (Front)
• Custom integrated bullbar
• Custom replacement bumper
• Midas driving lights
• 31" BFG KM3's
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
- Christian Kuun
- Town: Stellenbosch
- Vehicle: 2008 Tuna V6 4x4 Manual
- Real Name: Christian Kuun
Real men use their knives to shave....thats when it is sharp enough!
Wynkop Kuun
O82 6l5 8lO5
O82 6l5 8lO5
- Town: Centurion
- Real Name: Everdt
That explain why the razorblades dont last that long, because of their very sharpness they goes blunt that quicker.
Christian - those were the lekker cowboys days ne.
- Gunta
- Real Name: Mark
We used to sharpen a rock in the stone age to shave..... miss those days the woman never used to speak and complain.
- oxydog
- Real Name: Jarus
Remember this one?Gunta wrote:We used to sharpen a rock in the stone age to shave..... miss those days the woman never used to speak and complain.
- Teach women to talk.jpg (33.31 KiB) Viewed 3841 times
Bees (Toy)
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
- george
- Town: Velddrif
- Vehicle: Triton 3.5l V6
- Club VHF Licence: HC107
Good one Jarus.
I have recently started to us a diamond stone to hone me knifes.
I found with carbon compound knifes it takes considerable time to get a knife really sharp when using the lansky and other kits.
It takes a bit of practice to get the edge right,but once you find the edge it goes quick to keep your knifes sharpen.
- Gunta
- Real Name: Mark
He Heoxydog wrote:Remember this one?Gunta wrote:We used to sharpen a rock in the stone age to shave..... miss those days the woman never used to speak and complain.
