4.0 V6 D/Cab noisy back seat
- oxydog
- Real Name: Jarus
- Club VHF Licence: J67
Hi,
It seems the back seats of my 4.0 V6 D/Cab (bought only last week) don't lock properly. The latches hook over the brackets but there is a gap so that, when I change gears, the seat moves and makes an irritating noise. Any ideas on how to fix this?
Regards,
Jarus
Regards,
Jarus
Bees (Toy)
'98 Hilux 2.8D 4X4 D/Cab
• ARB Bullbar
• Safari Snorkel
• GearMax Rear Locker
• Front Runner bakkie slide
• 31" BFG KM2's
'06 Hilux 4.0 V6 4X4 D/Cab
• Level-it kit (Front)
• Custom integrated bullbar
• Custom replacement bumper
• Midas driving lights
• 31" BFG KM3's
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
- tersmit
- Town: Durbanville Cape Town
- Vehicle: '06 Hilux 4x4 4.0 Auto D/C, 185a/h Dual Battery Sistem, 1500w inverter
- Real Name: Tertius
Re: 4.0 V6 D/Cab noisy back seat
Same problem on my side, i have come to live with it
Factory fault with Toyota 05 / 06 models when they came out. Tahe it back to Toy and tel them to fix it
- oxydog
- Real Name: Jarus
Thanx guys, especially like Steve's solution ;). Think I'll ask Toy to fix it for me like Mark suggested.
Bees (Toy)
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
Fit some soft rubber buffers to the rear cab wall that keeps the seat under 'tension' when latched .... no more rattles.
- Royco
- Town: Stellenbosch
- Real Name: Roy
- Club VHF Licence: X88
There were some other suggestions here:
viewtopic.php?f=34&t=15011" onclick="window.open(this.href);return false;
I tried the piece of hose over the eye as a first option ... over a few years I had to try different hoses ... rubbers, plastics and they all failed with opening and closing the seat. If you don't use the space behind the seat for things that you need to access regularly then it's an option, but if you're in there every other day, the hose over the eye doesn't last. That's why I eventually made and fitted my own silicone rubber buffers. These were on the "missing" Lux, and I didn,t take any pics, but I'm sure you can get the idea.
Andrea's....Jardus drives a Vigo not a SFA :alvarin:Mud Dog wrote:I tried the piece of hose over the eye as a first option ... over a few years I had to try different hoses ... rubbers, plastics and they all failed with opening and closing the seat. If you don't use the space behind the seat for things that you need to access regularly then it's an option, but if you're in there every other day, the hose over the eye doesn't last. That's why I eventually made and fitted my own silicone rubber buffers. These were on the "missing" Lux, and I didn,t take any pics, but I'm sure you can get the idea.
- venom38
- Town: johannesburg
- Vehicle: hilux d4d
- Real Name: Corne
I had exactly the same problem. (2009 model DC) The best solution is to cut half of the catch off. (+- 40-45mm inner catch left) I will try to post some pics. Then either put some rubber hose around it or just some insulation tape (I went the insulation tape route- a lot) No more problems and the back seat can now open. There's a lot of extra space behind the back seat that was previously unavailable
- AM Racing
- Real Name: Dylan
venom38 wrote:I had exactly the same problem. (2009 model DC) The best solution is to cut half of the catch off. (+- 40-45mm inner catch left) I will try to post some pics. Then either put some rubber hose around it or just some insulation tape (I went the insulation tape route- a lot) No more problems and the back seat can now open. There's a lot of extra space behind the back seat that was previously unavailable
Quick 'n easy. Do the cutting of the hooks. It opens up the rear for storage and easy replacement of the vibration damper tape when it goes again
- oxydog
- Real Name: Jarus
Thanks guys, this helps a lot. Think I'll go for the insulation tape solution for now.
Bees (Toy)
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
My error .... sorry!OOOOMS wrote:Andrea's....Jardus drives a Vigo not a SFA :alvarin:Mud Dog wrote:I tried the piece of hose over the eye as a first option ... over a few years I had to try different hoses ... rubbers, plastics and they all failed with opening and closing the seat. If you don't use the space behind the seat for things that you need to access regularly then it's an option, but if you're in there every other day, the hose over the eye doesn't last. That's why I eventually made and fitted my own silicone rubber buffers. These were on the "missing" Lux, and I didn,t take any pics, but I'm sure you can get the idea.
- oxydog
- Real Name: Jarus
Guys, I've decided to put some tape on for now, but I'm not sure how to remove the back rest - some help please!
Bees (Toy)
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
- African Child
- Town: Grabouw
- Vehicle: Hilux 4L 4x4
- Real Name: Leon
Slaan die sitplek op. Haal die twee plastiek covers langs altwee kante van die sitplek af en draai die boude uit. Kry nog n paar hande en lug die rugleuning uit sy twee brackets teen die bak. Nou koop jy vir jou nog n yskas en sit hom vas op die vloer waar die sitplek vroeer gestaan het. Nou kan jy in die ry n koue drink uithaal en sonder die ekstra asems dit in stilte geniet.
- oxydog
- Real Name: Jarus
Thanks Leon, ek maak so.
Weet nie wat my vrou gaan sê nie, want ek kan jou verseker jr. gaan voor sit. Gelukkig het ek 'n canopy, so die wind sal haar nie so baie pla nie.
Bees (Toy)
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
- Modder
- Town: West Rand
- Vehicle: 2009 Hilux 3.0 D4D D/C 4x4
- Real Name: Alec
Ek het ook dieselfde probleem gehad. Daai rubbers val af.
Ek het nuwe rubbers by toyota gekry, so R35, en dit weer opgesit.
Maar ek het ook dit met insulation tape gedraai. nou is hulle stil.
Corne, kan jy asb fotos post, want ek sal graag ook my sitplek wil laat oopmaak van bo.
Ek hoor dat LA Sport glo n kit verkoop wat jou toelaat om dit te doen...
''Life is an adventure! Cheers!'' - Kingsley Holgate
Born to hunt, forced to work!
My hart is die bosveld, maar my gat is in die stad!!!
- oxydog
- Real Name: Jarus
Alec, Mark het ook van die LA Sport kit gepraat (per ongeluk by 'n ander Topic gepost: viewtopic.php?f=92&t=19486)
Bees (Toy)
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
- Town: Kyalami
- Real Name: Mike
I had the same problem, tried wrapping the eyes in Duct Tape, taht didnt work so lekka cos it just ripped it up when the seat is in place.
I eventually used vice grips, grip the eye on the rear wall and bend it ever so slightly up, this causes a tighter fit when the seat is replaced and no more rattles. Worked for me
- Town: White River
- Vehicle: Hilux Raider v6 4.0 ; SYNCRO 2l
- Real Name: Jan
Dieselfde frustrasie - hou van idea om ruimte agter sitplek te kan gebruik. Vir skoonma .....
se goedjies.
se goedjies.
- oxydog
- Real Name: Jarus
I phoned the guys at LA Sport Lynnwod Road - they don't know anything about such a kit?
Bees (Toy)
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
