Next Generation Dual Battery controller.
Members' DIY projects
Gertc
Vehicle: 3.0L Fortuner
Real Name: Gert Combrink
Club VHF Licence: Xray05
Post by Gertc »
DB Box.JPG (2.29 KiB) Viewed 4083 times
Next Generation Dual Battery controller.docx
(14.41 KiB) Downloaded 175 times
Dimensions 85 x 56 x 30 mm
2 x 16 character LCD screen
2 Button control
It is time to upgrade the Dual Battery system to something that is more useful l.
When the vehicle is switched on it will have a welcome screen
WELCOME
MASTER
Then it must check your Dual battery system.
SYSTEM CHECK
After the system check is completed.
Main Batt 13.8V
Aux Batt 12.2V
OR
Main Batt 13.8V
Aux Batt N/C
As soon as you start the vehicle the timer will start counting backwards
Connect Aux Batt
90 sec
After timer finished the countdown it will connect the Aux Batt.
Connect Aux Batt
Connected
Screen will return to.
Main Batt 13.8V
Aux Batt 13.2V
As soon as you switch of the vehicle it will show
Connect Aux Batt
Disconnected
Followed by
GOODBYE
MASTER
If the lights are left on a buzzer will alarm and the screen will show
Turn
LIGHTS OFF
The 2 buttons will be used to adjust the time for connecting the Aux battery or to connect the Aux battery when you need to or disconnect it if you don`t need it.
Any comments or suggestions welcome Good or Bad.
Mr_B
Vehicle: Honda Jazz
Real Name: Bretton
Re: Next Generation Dual Battery controller.
Post by Mr_B »
Jeesh Gert, I've just installed and started using the excellent version 1!
On v1 the aux battery connected after 5 minutes, with the v2 I see it's 90secs... why? (plz excuse my ignorance)...
v2... I like the fact that it's got a volts display... price?
Gertc
Post by Gertc »
The Idea is that you must be able to set your own time. 90 sec was just an example.
I will try and set it from 60 sec to 300 sec. The one I used in the Hilux was set at 60 sec. It worked well for me. When I go to town it took me about 6 minutes to get there and waiting 5 minutes was too long for me. So I set mine to 60 sec.
Price ????????!!!!!!!!!!!!!!!!!!!!!?????????????????
Well I hope to be able to sell them for +\- R450. It is still in the design phase and I struggle to get a good neat enclosure for it.
ThysdJ
Club VHF Licence: HC102
Post by ThysdJ »
Brilliant Gert!! :thumbup: :thumbup:
Post by OOOOMS »
Me also thinks 5 mins is too long :thumbup:
Nice work :thumbup:
bosjakkals
Town: Harrismith
Vehicle: 97 Hilux SFA ,31 BF's, Bullbar,Warn winch, Hunting frame, 2 spare wheels, Long range tank, High lift jack, Gearmax rear locker diff, Suspension unknown but very soft)
Real Name: CJ
Post by bosjakkals »
Ek kom oor 2 weke klerkdorp toe kan jy instaleer ook ?
Asseblief
03 - Cruiser 105 GX
97 - Hilux 2.4 D/C -
05 - Pajero 3.2 DID SWB ( Ma se kar)
01-Prado 3.0 d (Gesien -Geniet - GEROL))
Mr_B
Vehicle: Honda Jazz
Real Name: Bretton
Post by Mr_B »
Cool, on the enclosure side... is your plan to go split unit, control components in one and display in another, to keep the messy stuff out of eye view?? Will I be able to use all my present DB wiring, or will this unit require some sort of rewire?
Gertc
Post by Gertc »
The idea is to keep it as compact as possible, I will try to use only one box. Modify the wiring to use a plug in system. You will still need the old wiring. Maybe just extend the aux battery pickup to be as close as possible to the aux battery so that you get an accurate voltage reading.
Gertc
Post by Gertc »
bosjakkals wrote:Ek kom oor 2 weke klerkdorp toe kan jy instaleer ook ?
Asseblief
Jy is so bietjie haastig. Ek soek nog na die regte boks om die ding in temount. Intalasie sal ek jou raad gee. die res sal jy maar self moet doen.
Post by Family_Dog »
And I have seen the prototype! ;)
Post by CasKru »
Ek weet van nog iemand wat dalk sal belang stel
The Legend
Real Name: Dawie
Club VHF Licence: X93-
Post by The Legend »
Miskien n stupid vraag.Sal dit ek dit kan gebruik op my NL portable dual battery system?
Bushwacker
Town: Vryheid Natal
Real Name: Piet
Post by Bushwacker »
Daai klink great Gert!!!
Mr_B
Vehicle: Honda Jazz
Real Name: Bretton
Post by Mr_B »
One more thought Gert... yes I know this may be a long shot... any possibly to backlight/illuminate the display... would be cool for low light conditions!
krazy_kameleon
Town: Fourways
Vehicle: 1993 Hilux D/C 4X4 2.4 22R (fuel injection in the pipeline)
Real Name: Rick
Post by krazy_kameleon »
Mr_B wrote:One more thought Gert... yes I know this may be a long shot... any possibly to backlight/illuminate the display... would be cool for low light conditions!
Nice suggestion - that would be cool
witmamba
Town: Sasolburg
Vehicle: D4D 4x4 Lux + D4D 4x4 Tuna
Real Name: Hans
Post by witmamba »
Hi Gert, as jy die wiele aan die rol het, moet jy my asb kontak sodat ek van daai units kan toets en in my winkel kry.
Groete!
Life only starts . . . . where comfortlevels end
Donkey
Club VHF Licence: X122
Post by Donkey »
Brilliant concept Gert. When you're ready to manufacture please put me on the buyer's list, Master - :taunt: :laugh2:
Tumelo Maketekete
Royco
Town: Stellenbosch
Real Name: Roy
Club VHF Licence: X88
Post by Royco »
Gertc wrote:The Idea is that you must be able to set your own time. 90 sec was just an example.
What about setting a personal greeting too ... ?
WELCOME
ROY
:boss:
Image Image Image Image
Gertc
Post by Gertc »
Back light will be standard when any button is pressed. Or would you prefer back light work with the vehicle lights?
Gertc
Post by Gertc »
Lollie wrote:Miskien n stupid vraag.Sal dit ek dit kan gebruik op my NL portable dual battery system?
Sal moet kyk maar ek glo jy sal hom saam kan gebruik.
Post by CasKru »
Gertc wrote:Back light will be standard when any button is pressed. Or would you prefer back light work with the vehicle lights?
Dink opsie een want mens gaan heel waarskynlik wil sien wat op die display aangaan voor jy ry of na jy klaar geparkeer het
krazy_kameleon
Town: Fourways
Real Name: Rick
on with vehicle lights :thumbup:
swartvark
Town: Gordons Bay
Real Name: Tiaan
Post by swartvark »
I'll get it just to greeted as....... MASTER!!! :twisted:
MUD........GLORIOUS MUD!!!!!
NEED A CAR?
talk2tiaan@gmail.com
0829294028
Post by CasKru »
So then at night you would need to switch on the cars lights just to check the voltage?
Mr_B
Vehicle: Honda Jazz
Real Name: Bretton
Post by Mr_B »
Gert, is both not an option, when vehicle lights are on, display's backlight is on... and if vehicle is off and button is pressed, then backlight comes on and unit shows voltage, with auto-off timer... say 10 secs... best of both worlds!
Gertc
Post by Gertc »
Mr_B wrote:Gert, is both not an option, when vehicle lights are on, display's backlight is on... and if vehicle is off and button is pressed, then backlight comes on and unit shows voltage, with auto-off timer... say 10 secs... best of both worlds!
Can be done
Mr_B
Vehicle: Honda Jazz
Real Name: Bretton
Post by Mr_B »
Ok seen as we are pushing our luck... integrate a small coffee maker and heating element, with temp control... don't want to burn the brew you know! With auto dispense controller...
Gertc
Post by Gertc »
Get married!!!!!!!!!!!!!!!!!!!!!!!!
Mr_B
Vehicle: Honda Jazz
Real Name: Bretton
Post by Mr_B »
Problem is... I am!
krazy_kameleon
Town: Fourways
Real Name: Rick
Gertc wrote:Get married!!!!!!!!!!!!!!!!!!!!!!!!
:lmao:
truckin
Town: Durbanville
Vehicle: 2006 2.7VVTI Hilux SRX Single Cab 4x4
Real Name: Juan
Post by truckin »
dis n bakgat idee, net n vraagie, sal n mens dit kan maak om 2 spaar baterye apart te charge?
“The shinbone is a device for finding furniture in a dark room.”
“When I die, I want to die like my grandfather, who died peacefully in his sleep. - Not screaming like all the passengers in his car -
Gertc
Post by Gertc »
truckin wrote:dis n bakgat idee, net n vraagie, sal n mens dit kan maak om 2 spaar baterye apart te charge?
op spasial order ja.
Return to “Build your own:”
