Metal Jerrycans for water?
Eyeman
Town: Jeffreys Bay
Vehicle: Hilux KZ-TE D/C 4x4
Real Name: Grant
Post by Eyeman »
Does anybody have advice regarding the use of the normal metal jerrycans for water storage?
Re: Metal Jerrycans for water?
Post by CasKru »
As far as I know one can only use the light blue can's to hold water.
truckin
Town: Durbanville
Vehicle: 2006 2.7VVTI Hilux SRX Single Cab 4x4
Real Name: Juan
Post by truckin »
CasKru wrote:As far as I know one can only use the light blue can's to hold water.
the blue one is for water, you'll see the lid is different too, i normaly poor half a teespoon of "jik" into the water when i go on long trips, it helps take out that metal taste, and keeps the water fresher for longer
“The shinbone is a device for finding furniture in a dark room.”
“When I die, I want to die like my grandfather, who died peacefully in his sleep. - Not screaming like all the passengers in his car -
3RZ
Vehicle: 2004 Legend 35 Hilux 2.7 DC 4x4
Real Name: Willem Grimsell
Post by 3RZ »
I have been using mine for about six years now and would not use anything else. It is coated with what looks like epoxy on the inside and have survived where plastic cans could not.
Post by CasKru »
3RZ wrote:I have been using mine for about six years now and would not use anything else. It is coated with what looks like epoxy on the inside and have survived where plastic cans could not.
You are referring to the blue ones nê?
The ones for fuel (green,red and yellow) does not have this epoxy on the inside.
3RZ
Post by 3RZ »
Correct, dem blue ones.
Eyeman
Town: Jeffreys Bay
Real Name: Grant
Post by Eyeman »
These are the metal jerrycans??
Post by CasKru »
Eyeman wrote:These are the metal jerrycans??
Correct
The blue ones are for water
Eyeman
Town: Jeffreys Bay
Real Name: Grant
Post by Eyeman »
Thanks.
Any views on the plastic jerrycans?
Post by CasKru »
Typically, the following NATO color coding is used:
Color - Use
Red - Gasoline(Lead-replacement)
Green - Gasoline (unleaded)
Yellow - Diesel
Blue - Kerosene
Light Blue - Water (usually labeled)
krazy_kameleon
Town: Fourways
Vehicle: 1993 Hilux D/C 4X4 2.4 22R (fuel injection in the pipeline)
Real Name: Rick
Post by krazy_kameleon »
I second that! I have 3 (total 60l)
krazy_kameleon
Town: Fourways
Real Name: Rick
CasKru wrote:Typically, the following NATO color coding is used:
Color - Use
Yellow - Diesel
Blue - Kerosene
better check for kerosene before I think its all water next time :razz:
Return to “Open Discussion”
