Hi Guys
I have been searching for a few weeks now and seriously need some advice.
The ABS unit on our 2002 KZTE has popped and I really want to replace it. The stealers are quoting R14k, which is a bit steep for the moment. I can import a recon unit for R2k but want to see if there is any local person doing similar recons as there is a better chance of follow up should something be wrong with the unit.
I would greatly appreciate it if you could please put me in the right direction. The unit I am looking for is AISIN part 44150-35080.
Donovan
Zero8two 9four double 1 236
Help looking for second hand / recon ABS pump and ECU
Re: Help looking for second hand / recon ABS pump and ECU
Give BCON a call, Krugersdorp, maaaaaybeeeee he can help.
07three437821five
07three437821five
- Town: Randburg
- Vehicle: KZTE
- Real Name: Donovan
Thanks OOOOMS
I'll be calling around later this week.
