Anyone seen these motors lately at the importers? Toyota supra 2JZGE,Its for a friend.
2JZ-GE
The 2JZ-GE is a common version. Output is 220 hp JIS (158 to 169 kW) at 5800 to 6000 rpm and 209 to 220 ft.lbf (283 to 298 Nm) of torque at 3800 to 4800 rpm.
It uses Sequential Electronic Fuel Injection, has an aluminum head and 4 valves per cylinder with some versions using VVT-i, along with a cast iron cylinder block.
Applications:
Toyota Altezza / Lexus IS 300
Toyota Aristo / Lexus GS 300
Toyota Crown/Toyota Crown Majesta
Toyota Mark II
Toyota Chaser
Toyota Cresta
Toyota Progres
Toyota Soarer / Lexus SC 300
Toyota Supra MK IV
2JZGE
- Rebel 4x4
- Town: Port Elizabeth
- Real Name: Thomas
Re: 2JZGE
My Oom het ook so paar maande terug gepraat van die Supra engine vir sy D/C Hilux. Nog niks weer gehoor nie. Sal bietjie uitvind waar hy die engine vandaan sou kry.pampoen wrote:Anyone seen these motors lately at the importers? Toyota supra 2JZGE,Its for a friend.
2JZ-GE
Applications:
Toyota Mark II
Toyota Chaser
Toyota Cresta
Toyota Progres
Toyota Supra MK IV
- Town: Johanesburg
- Vehicle: 1999 2700i Hi Lux
Re: 2JZGE
Engine Den had a few the last time I checked their website http://www.engineden.co.za" onclick="window.open(this.href);return false;
- Spartan
- Town: Vanderbijlpark
Re: 2JZGE
Nope, if you cut the fire wall you don't know how to install a 2jMr_B wrote:Spartan, did you have to cut into the firewall or in front to fit the engine? Some okes are telling me the 2JZ is too long for the SFA engine bay...
I am running a Go-Tech Pro-X to be able to drive the VVT-i but for a non VVT-i you can use the mini-x from Go-Tech, it works like a charm.pampoen wrote:And are you running a standard ECU?
MOBILITATE VINCERE
Spartan
Spartan
