Ok the book says that the 2L diesel motors nominal compression pressure should be 455 psi, minimum 284 psi and the maximum variation between cylinders of 71psi.
Cylinder 1 is 500 and leakdown is 8%
Cylinder 2 is 350 and leakdown is 30%
Cylinder 3 is 440 and leakdown is 26%
Cylinder 4 is 500 and leakdown is 10%
So cylinder 2 is way out of allowed spec and cylinder 3 is borderline.
Can someone please help me understand what this means for the engine and if I can rely on it or not.
Help Please : Diesel 2L Engine Compression
- SYRON CONVERSIONS
- Town: Tamboekieland
- Vehicle: SFA HILUX
- Real Name: SIMON
Re: Help Please : Diesel 2L Engine Compression
What application did you use when you did the check, did you use a dummy injector connected to the tester gauge.
simoan
simoan
- SYRON CONVERSIONS
- Real Name: SIMON
If your readings are correct, they seem to be within spec refering to your book, but cylinder 2 could be a problem, but depending on where and how you will be using this vehicle will determine if you want to do an overhaul, do not think that with the replacement of only the rings will sort this problem out. It will not.
simoan
simoan
