I want to see how long my fridge can run on two batteries connected to the solar panel.
I know this is a theoretical test as the house is a lot cooler than a tent(!!), the fridge gets loaded with warm items and gets opened often...
My setup is the following:
- • 90w Solarworld Solar Panel (5.1amp output)
• Phocos CML10 10A solar regulator
• 2x Deltec 105Ah Deep Cycle batteries
• National Luna Weekender 50-Twin
The panel is not always in direct sun, I attached it on the pergola where it gets midday and afternoon sun.
I did not charge the batteries, but they are new and with no load, were reading at 12.8v.
The fridge was running off the 220v for 2 days prior to connecting the batteries, and the lid is cabled tied to prevent it from being opened.
The two batteries are connected in parallel and the fridge is connected directly to one of the batteries, not to the regulator.
I have a temperature gauge that I was going to add to the test, but that seems pointless as the fridge temperature will always remain within 3 degrees.
The fridge has been set to zero and the freezer is 10 degrees lower (ie -10)
I connected the fridge to the batteries and removed the 220v yesterday 05 Feb 2011 at 19:00.
Any questions or comments will be gladly received...
